Using PayPal- IMPORTANT!!
2009-12-29 by Paul Schreiber
2010-02-25 by Miguel Mendoza
2010-02-26 by Richard Brewster
> Hello, I'm wondering if my MOTM 101 is working fine. All the sections
> work but I have always been thinking that the SH output has a very
> smooth, subtle response. Even I only coud hear small pitch changes on
> a VCO if I put the SH level at 10.
> Today I connected it to my 730 DIV MOD input and it didn't change any
> value. Other signals like LFOs were modulating de /N output but the SH
> does nothing.
> I checked the SH output with a digital voltimeter and it was
> changing values at every clock pulse as expected but all of them were
> positive from 0 to 3.4 v. aprox. I was checking it for a while and I
> couldn't read any higher than 3.4 v. and all of them were
> positive. The level pot was at 10 all the time.
> So, anybody can say if this is normal? Any tip?
> Thanks in advance.
> Miguel.
2010-02-26 by Jason Proctor
>Have you tried patching a large signal into the S&H input? Patch the
>Triangle output of a MOTM-300. Run the 300 at the lowest frequency. If
>you're not getting any negative output from the 101, something is wrong
>with the sample and hold section. If this test works, there may be a
>problem with the Pink noise on the 101. Try adjusting the noise gain
>trimpot, TP1.
>Richard Brewster
>http://pugix.com
>> does nothing.
>> Thanks in advance.
>> Miguel.
>Yahoo! Groups Links
2010-02-26 by Miguel Mendoza
also i'm suspicious that giving the 101 CVs of 0-3.4v is resulting in
small pitch changes only. that should be a 3.4 octave range.
does the
101 CV input work reliably with other CV sources?
>Have you triedpatching a large signal into the S&H input? Patch the
>Triangle outputof a MOTM-300. Run the 300 at the lowest frequency. If
>you're not gettingany negative output from the 101, something is wrong
>with the sample andhold section. If this test works, there may be a
>problem with the Pinknoise on the 101. Try adjusting the noise gain
>trimpot,TP1.
>href="http://pugix.com">http://pugix. com
>Richard Brewster
>wrote:
>Miguel Mendoza
>> work but I have always beenthinking that the SH output has a very
>> smooth, subtle response. EvenI only coud hear small pitch changes on
>> a VCO if I put the SH levelat 10.
>> value. Other signals like LFOs were modulatingde /N output but the SH
>> does nothing.checked the SH output with a digital voltimeter and it was
>> I
>> changingvalues at every clock pulse as expected but all of them were
>> positive.The level pot was at 10 all the time.
>> So, anybody can
>>advance.
>> Thanks in
>>Miguel.
>>Groups Links
>Yahoo!
