Panning
Panning
2009-11-06 by crmatt99
O.K. so I decided to try with a couple of vca to make a panning patch which went as follows.
300 saw output to multiple to 2 different vca's.
320 sine out to multiple.
320 from multiple 1 to vca 1 cv input
320 from multiple 2 to 830 mixer input 2 attenuator negative 5 output to vca 2 cv input.
vca 1 out to left.
vca 2 out to right.
...and here is where i realize that as the sine wave from the 320 is crossing zero the volume of each vca is at half.
Is there a simple method to achieve panning that I might a have missed.
I have these modules
101
120
190x2
300x2
320
390
410
420
440
510
650
800x4
830
Re: [motm] Panning
2009-11-06 by Scott Juskiw
You need one LFO, one inverter, two VCAs, and your audio signal. Audio
signal goes to audio input on both VCAs. LFO output goes to VCA #1 CV
input. LFO output also goes through inverter, the inverter output goes
to VCA #2 CV input. You'll have to add a +5V offset to each VCA if the
LFOs are +/-5V (most likely they are). I have a couple of panning
audio examples at the bottom of this page:
http://tellun.com/motm/diy/tln132/TLN-132.html
The VCAs I used for these demos have reversing attenuators built in.
> vca 1 out to left.
> vca 2 out to right.
> missed.
> 101
> 120
> 190x2
> 300x2
> 320
> 390
> 410
> 420
> 440
> 510
> 650
> 800x4
> 830
Re: Panning
2009-11-06 by johnspeth
(etc)
And so much patch work and module usage for a seemingly simple function. :(
I've been jonesing for it since the start of MOTM and I'll ask it again:
Paul, Is there anything in the MOTM design pipe like a VC panner? If so, when?
And while I'm asking for long lost planned modules, How about an external signal amplifier/voltage follower?
JJS
Re: [motm] Re: Panning
2009-11-06 by Ben Stuyts
> (etc)
> function. :(
Agreed!
> again:
> If so, when?
Not Paul, but I'll give it a go. :-) If you can DIY, the Stereo Panner
from Music From Outer Space might be what you are looking for. (http://www.musicfromouterspace.com/analogsynth/STEREOPANNER/STEREOPANNER.html
Maybe the Oakley Envelope Follower and Gate Extractor (http://www.oakleysound.com/follower.htm
With kind regards,
Ben
2009-11-06 by Ti_
Also, if you don't particularly want to solder up the bits and pieces yourself, it would still be fairly simple and just about as cheap as diy to get yourself a 1 space blank MOTM panel, an MOTM-995 power distro board, and a Synthesizers.com Q111 panner. Then all you'd have to do is drill a few holes, take the pieces from the Dotcom panel and put 'em in the blank and label the jacks and switches however you please!
Or, if you have wood rails in your box and don't mind mixing up the styles a bit, just put the Dotcom module in there with the 995 board, although you'd have to drill an extra hole or two and you'll end up with gaps on one side or the other of the module.
Then once you have the power distribution for Dotcom modules, then you could take advantage of the Q118 Instrument Interface that has the envelope follower plus the gate and trigger extractors!
~Ti_
To: johnspeth <johnspeth@...>
Cc: motm@yahoogroups.com
Sent: Fri, November 6, 2009 10:56:41 AM
Subject: Re: [motm] Re: Panning
> (etc)
> function. :(
Agreed!
> again:
> If so, when?
from Music From Outer Space might be what you are looking for. (http://www.musicfro mouterspace. com/analogsynth/ STEREOPANNER/ STEREOPANNER. html
With kind regards,
Ben
