no-clean solder
2009-08-01 by chris walcott
2009-08-01 by wjhall11
--- In motm@yahoogroups.com, chris walcott <cedubstudio@...> wrote:
> hello list. i am running out of no-clean solder that i've gotten from paul
> over many kits and was wondering what to order. does anyone have a mouser
> part number?
> thanks!
2009-08-01 by John L Rice
paul
> part number?
> thanks!
Yahoo! Groups Links
--- In motm@yahoogroups.com, "John L Rice" <Drummer@...> wrote:
> Check out All-Spec too, pretty good prices on Kester! ;-)
> 24-6337-6401 organic $23.99
> http://www.all-spec.com/products/KW33105.html
> 24-6337-8814 no-clean $21.62
> http://www.all-spec.com/products/KW24540.html
> John L Rice
> -----Original Message-----
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
> wjhall11
> Sent: Saturday, August 01, 2009 10:41 AM
> To: motm@yahoogroups.com
> Subject: [motm] Re: no-clean solder
> Hi Chris -
> 533-24-6337-6401 - organic
> 533-24-6337-8814 = no-clean
> http://www.mouser.com/catalog/catalogUSD/639/2148.pdf
> Bill and Will
> paul
> > part number?
> > thanks!
2009-08-01 by Miguel Mendoza
2009-08-01 by Ben Stuyts
> Hi group, I'm starting to build a MOTM 300 kit that I was keeping onIt's not that critical. Optimally, it should be the same as the input
> a shelf and I'm missing the 22K resistor for R49. I'd like to ask if
> any of you know if I can replace this one by other value and what
> range or if this is a critical value. I have many other resistors
> and I would like to finish mounting the oscillator on this weekend...
2009-08-02 by Paul Schreiber
----- Original Message -----From: Miguel MendozaSent: Saturday, August 01, 2009 5:58 PMSubject: [motm] Missing resistorHi group, I'm starting to build a MOTM 300 kit that I was keeping on a shelf and I'm missing the 22K resistor for R49. I'd like to ask if any of you know if I can replace this one by other value and what range or if this is a critical value. I have many other resistors and I would like to finish mounting the oscillator on this weekend...Thanks!Miguel.
2009-08-02 by Miguel Mendoza
----- Original Message -----From: Paul SchreiberSent: Sunday, August 02, 2009 2:02 AMSubject: Re: [motm] Missing resistor
Correct, not critical, 15K to 33K will work, 5% ok.Bonus: what is the specific *purpose* of this resistor, and ...Bonus #2: what "bad effect" results from using it (but is compensated for later in the design, and what is THAT compensation? )Paul S.----- Original Message -----From: Miguel MendozaSent: Saturday, August 01, 2009 5:58 PMSubject: [motm] Missing resistorHi group, I'm starting to build a MOTM 300 kit that I was keeping on a shelf and I'm missing the 22K resistor for R49. I'd like to ask if any of you know if I can replace this one by other value and what range or if this is a critical value. I have many other resistors and I would like to finish mounting the oscillator on this weekend...Thanks!Miguel.
2009-08-02 by Ben Stuyts
> Bonus: what is the specific *purpose* of this resistor, and ...Oooh, pick me, pick me! :-) (Although it's been a while...)
> Bonus #2: what "bad effect" results from using itIt is a carbon resistor, with a 200-250 ppm temp coef. The resistors
> (but is compensated for later in the design, and what is THATBit of a guess here: normally you would only need 3300 ppm tempco to
> compensation?)
2009-08-02 by Richard Brewster
>__________ Information from ESET NOD32 Antivirus, version of virus signature database 4297 (20090801) __________
> for later in the design, and what is THAT compensation?)
> Paul S.
> *From:* Miguel Mendoza <mailto:miguel@...>
> *To:* motm@yahoogroups.com <mailto:motm@yahoogroups.com>
> *Sent:* Saturday, August 01, 2009 5:58 PM
> *Subject:* [motm] Missing resistor
> on this weekend...
> Thanks!
> Miguel.
> The message was checked by ESET NOD32 Antivirus.
> http://www.eset.com
>This is correct but only half the answer. Keep going.............
> The input bias current into the minus input causes a voltage drop
> across the input resistors. This would then be amplified and to
> compensate for this, that resistor is added on plus input to generate
> an equal voltage on the plus input. Net effect should then be zero at
> the output.
>> Bonus #2: what "bad effect" results from using itNo, but a good guess :)
> on the minus input are much better, so you get temperature drift.
>> compensation?)
> compensate the expo converter, but you are using a 3500 ppm tempco
> resistor. Is that the reason?
> According to the Musical Engineer's Handbook (Bernie Hutchins, 1975), 3aThis is sort of a "hand waving" answer you write on a test when you forgot
> (10), "The purpose of the resistor is to compensate for the offset due to
> the current that actually flows into the other input." It is important to
> use in precision DC summing circuits.
> The MEH also tells how to calculate the value.Well that part is correct.
> I've wondered how important this resistor is in an inverting summer.Application dependent.
>It's a toughie :)
2009-08-02 by JH.
>Bonus #2: what "bad effect" results from using it (but is compensated for later in the design, and what is THAT compensation?)
2009-08-02 by Craig Critchley
>It's a toughie :)
