wiring 101 question
wiring 101 question
2009-07-18 by patchdub1972
hi folks.
so i am wiring the 101 right now and just realized there is a special coax for the s&h in jack.  i don't have this cable, will some combination of rg-174 and hook up wire work instead?
thanks
-patch
RE: [motm] wiring 101 question
2009-07-18 by John L Rice
Yes, I think that would work just fine. I don't think you need the hookup
wire do you? Just a piece of the rg-174. (the rg-174 you have is coax isn't
it?)
Best of luck!
John L Rice
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
patchdub1972
Sent: Friday, July 17, 2009 10:57 PM
To: motm@yahoogroups.com
Subject: [motm] wiring 101 question
hi folks.
thanks
-patch
Yahoo! Groups Links
Re: [motm] wiring 101 question
2009-07-18 by Paul Schreiber
Sure, run the RG-174 from pin 2 and 3 of the pc board to the top terminal
and ground terminal of the jack. This connects the pink noise to the
switching side of the jack. Then run a discrete wire from pin 1 of the pc
board to the input side of the jack.
