Index last updated: 2026-03-31 01:40 UTC
installing a 960?
installing a 960?
2009-06-12 by patchdub1972
hi folks.
whats the best way to go about installing a 960 to the 900?
thanks!!
-patch
RE: [motm] installing a 960?
2009-06-12 by John L Rice
Possibly the easiest way if there is enough slack on the MOTM-900 wires
would be to cut the 3 wires going from the supply to the distro board in
half, strip the ends prepare 3 new pieces of wire with stripped ends long
enough to reach your 960 and then use wire nuts to connect the ends
together. Not crimping or soldering required. Now, what the 'best' method is
I can't say! ;-)
Best of luck,
John L Rice
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
patchdub1972
Sent: Thursday, June 11, 2009 7:38 PM
To: motm@yahoogroups.com
Subject: [motm] installing a 960?
hi folks.
thanks!!
-patch
Yahoo! Groups Links
Re: installing a 960?
2009-06-13 by patchdub1972
this is from paul and i thought i would pass it on...
"Use a MOTM-20 or -30 jumper cable (just plug them together)."
probably because this involved power i was expecting something a little more complicated. i am always very relieved after i build a module and power it up for the first time there are no sparks or poofs of smoke!
-patch
> I can't say! ;-)
> Best of luck,
> John L Rice
> -----Original Message-----
> patchdub1972
> hi folks.
> thanks!!
> -patch
