Motm300(DIY)is not running
2009-05-30 by funkyfortyatyahu
Hello @all, ( might be my first post here ) I have populated 4x Motm300 PCBs. Two Modules were built in motm Format with onboard Pots, and those are running fine, no Issues. Then i built the third one in euroformat and this one makes nothing, it's dead, exept that it makes noises, especially when i turn the coarse pot. all Boards were populated in parallel, there should really be no fault, so my first assumption is that i have a bad part. The Styroflex Cap in the core i replaced allready. It's still the same. Power i measured on the IC sockets on all Boards together bevore i puted in the ICs as far i remember ( they were stuffed 5-6 month ago ) Hope to get some advice for debugging / measurings. thanks
