Re: [sdiy] Re: Taking pre-orders for JH. 36dB/oct LPF now
2009-05-28 by JH.
>Thank you. I hope the pre-order phase is not closed
I've ordered the boards from the factory already, but I always get more than
I've ordered (and have to pay them: small print of contract that I have to
take over-production), and I also order a few more than I have pre-orders
for. :)
>I guess a third way to build the varislope would be to omit the
>modulation source but keep the DG419 so it can still be a phaser
>or filter.
Yes. And there are probably a hundred other options, too. I leave this to
the diy-builder himself.
>Personally, I'm not sure about this modulation source. I suspect
>that, on my unit, the waveform pot would be permanently stuck in
>pure sine position, making the scanner redundant.
I am *very* sure about this modulation source, because I came to love it in
my JH-4 synthesizer module over many years.
Don't under-estimate the Sample&Hold modulation on a phaser with high
resonance! And this is a very special S&H, with a kind of overshot or spike
(for lack of better description) at the beginning of each new random sample,
which makes the S&H more "agressive" than a "perfect" S&H would be.
But there is more:
The waveform crossfading ("scanner") is arranged ina way that S&H is
adjoining "square" on the left side, and "self-modulation" on the right
side. That means, in S&H position you have true random staircases. Turn the
waveform pot slightly to the left, and you get a tad of regular rectangle
mixed in: the steps become less random in a way that large steps are more
likely. Turn the waveform pot slightly to the right, and the random S&H gets
mixed with the dirt of an audio-rate self-modulated filter. That's
especially impressive at high resonance settings. I got the idea for this
from the Prophet 5's Poly-Modulation and the CS-50's and Minimoog's external
modulation input, and - for a phaser application - from the EMS Synthi
HiFli.
>The other
>sources I see myself using (velocity, EG and sawtooth LFO) all
>have to come from other modules anyway.
Yes, it makes a lot of sense to use external modualtion sources. My on-board
modulation source is kind of special (I hope!), but it doesn't have saw
waveforms, for instance. And for VCF applications, you need an ADSR of
course.
>In theory, each pole could individually be switched between
>all-pass (phaser) and low-pass (filter) under voltage control. If
>all poles are sonically interchangeable, a single CV could be
>used with the number of LP poles being 6/5 of the CV. No idea how
>to do that, nor how useful it would be.
I'm not entirely sure if I understand what you mean. But the 6 stages are
interchangeable only with the "Slope" (or pole spread) potentiometer at ccw
position. When the poles are spread apart, it makes a difference which one
gets the complementary zero (= switchet to all pass), and which one doesn't.
JH.
2009-05-31 by Andre Majorel
> get more than I've ordered (and have to pay them: small print of
> contract that I have to take over-production),
Interesting commercial practice.
> love it in my JH-4 synthesizer module over many years.
> high resonance! And this is a very special S&H, with a kind of
> overshot or spike (for lack of better description) at the
> beginning of each new random sample, which makes the S&H more
> But there is more:
> S&H is adjoining "square" on the left side, and
> "self-modulation" on the right side. That means, in S&H position
> you have true random staircases. Turn the waveform pot slightly
> to the left, and you get a tad of regular rectangle mixed in:
> random S&H gets mixed with the dirt of an audio-rate
> self-modulated filter. That's especially impressive at high
> resonance settings. I got the idea for this from the Prophet 5's
> Synthi HiFli.
Thanks for the explanations. Where does the self modulation comes
from ? lfo_mod seems to be in the wrong direction. Perhaps AUX
MOD IN should be normalled to something else than ground ?
> >The other sources I see myself using (velocity, EG and sawtooth
> >LFO) all have to come from other modules anyway.
> My on-board modulation source is kind of special (I hope!), but
> it doesn't have saw waveforms, for instance.
Seen from here, it's plenty special. :-)
This is what I had in mind :
CV		Pole 1	Pole 2	Pole 3	Pole 4	Pole 5	Pole 6
       ~ 0.42 V	LP	LP	LP	LP	LP	LP
0.42 V ~ 1.25 V	LP	LP	LP	LP	LP	AP
1.25 V ~ 2.08 V	LP	LP	LP	LP	AP	AP
2.08 V ~ 2.92 V	LP	LP	LP	AP	AP	AP
2.92 V ~ 3.75 V	LP	LP	AP	AP	AP	AP
3.75 V ~ 4.58 V	LP	AP	AP	AP	AP	AP
4.58 V ~       	AP	AP	AP	AP	AP	AP
The idea is that the higher the CV, the more high frequency
content there is.
Looks like it could be done with an LM3914-type circuit.
> But the 6 stages are interchangeable only with the "Slope" (or
> pole spread) potentiometer at ccw position. When the poles are
> spread apart, it makes a difference which one gets the
> doesn't.
Okay, so there are not 7 but 2**6 = 64 combinations. I can't think
of a way to map this six-dimensional space to a scalar. Not one
that would be acoustically intuitive, anyway.
Ordering the combinations by amount of HF energy is not
straightforward because a combination that has more HF than
another when the first pole is at 100 Hz might have less when it's
at 5 kHz or vice-versa.
Ditto for ordering by response at 20 kHz (or any other fixed
frequency).
Andr\ufffd Majorel <URL:http://www.teaser.fr/~amajorel/>
