Can static electricity damage components?
2009-03-01 by Argitoth
2009-03-01 by John L Rice
On Sun, Mar 1, 2009 at 12:20 AM, John L Rice <drummer@...> wrote:
> Semiconductors mostly. (chips and transistors etc.) Some are more sensitive
> than others but just use common sense and you should be fine. Lots of info
> on the web. This video may interest you:
> http://www.youtube.com/watch?v=9NX7eS7dtFk
> John L Rice
> -----Original Message-----
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
> Argitoth
> Sent: Saturday, February 28, 2009 10:40 PM
> To: motm@yahoogroups.com
> Subject: [motm] Can static electricity damage components?
> When I'm doing my first DIY project, what kind of parts are sensitive
> to static electricity?
> www.elanhickler.com
www.elanhickler.com
sensitive
> John L Rice
> Argitoth
> www.elanhickler.com
www.elanhickler.com
Yahoo! Groups Links
On Sun, Mar 1, 2009 at 1:34 AM, Argitoth <argitoth@...> wrote:
> If you cut the lead before you solder, how can the component stay in place?
> On Sun, Mar 1, 2009 at 1:28 AM, John L Rice <drummer@...> wrote:
>> Make sure you watch this soldering video, it is really well done!
>> http://www.youtube.com/watch?v=I_NU2ruzyc4
>> John L Rice
>> Argitoth
>> Sent: Saturday, February 28, 2009 11:44 PM
>> Subject: Re: [motm] Can static electricity damage components?
>> thanks, I'll watch the soldering videos too.
>> sensitive
>>> John L Rice
>>> Argitoth
>>> www.elanhickler.com
>> www.elanhickler.com
>> Yahoo! Groups Links
> www.elanhickler.com
www.elanhickler.com
On Sun, Mar 1, 2009 at 2:05 AM, John L Rice <drummer@...> wrote:
> Actually, that's the only bit of bad advice in that video. I even mentioned
> that in the comments and the guy responded and agreed he needs to redo that
> bit. I think he said that cutting the leads is something done by the
> military or NASA because they need ultra high reliability and cutting leads
> could put stress on the joint.
> I've never worried about that and I never will! ;-) Just get some good
> sharp diagonal cutters and you'll be fine.
> John
> From: Argitoth [mailto:argitoth@...]
> Sent: Sunday, March 01, 2009 12:35 AM
> To: John L Rice
>> John L Rice
>> Argitoth
>> sensitive
> info
>>> John L Rice
>>> Argitoth
>>> www.elanhickler.com
>> www.elanhickler.com
>> Yahoo! Groups Links
> www.elanhickler.com
www.elanhickler.com
2009-03-01 by loopcycle
--- On Sun, 3/1/09, Argitoth <argitoth@...> wrote:
> From: Argitoth <argitoth@...>
> Date: Sunday, March 1, 2009, 1:10 AM
> One other question, do I need to worry about heat damaging
> components
> that I need a heat sink of some kind?
> > John
> > To: John L Rice
> components?
> really well done!
> >> John L Rice
> >> Argitoth
> components?
> etc.) Some are more
> >> sensitive
> > info
> >>> John L Rice
> >>> Argitoth
> components?
> >>> www.elanhickler.com
> >> www.elanhickler.com
> >> Yahoo! Groups Links
> > www.elanhickler.com
> www.elanhickler.com
2009-03-01 by Richard Brewster
>>> John L Rice
>>> Argitoth
>>> sensitive
>>>> John L Rice
>>>> Argitoth
>>>> www.elanhickler.com
>>> www.elanhickler.com
>>> Yahoo! Groups Links
>> www.elanhickler.com
2009-03-01 by Graham Atkins
On 1 Mar 2009, at 15:50, Richard Brewster wrote:
> I
> always press leads all the way over to the board, so they are not
> sticking up, but are lying flat. This is called crimping the lead to
> the board. I'll crimp lots of parts, then cut all the leads, solder,
> wash. They don't fall out, because they're crimped. I received some
> kits from John Blacet with all resistors installed and crimped, but
> not
> soldered. They stayed in place during shipping.
"Crimping" means forming the leads in some way. Some radial capacitors
for example have the leads cut short and formed with a small "wave"
which
helps them to be pushed into the PCB and holds them whilst soldering.
Just folding the leads through 90 deg to be flush with the board is
not really
crimping and also makes the component much harder to desolder and remove
the component to change / repair.
Graham
> Richard,
>> I
>> not
> which
> not really
> Graham
2009-03-01 by Paul Schreiber
> Cutting a lead can loosen a well-soldered component?No, that part of the video was BS :)
2009-03-02 by Argitoth
2009-03-02 by George Kisslak
> I've heard the term 'crimping' used to describe what I do, but I
> understand your meaning. I do fold the leads 90 degrees to lie flat on
> the board and then cut them before soldering. I've never found this to
> be a problem for desoldering. A good quality solder wick will suck up
> all the solder and leave the wire easily lifted. (Is there a good video
> on desoldering, I wonder?) Then again, I've done a lot of circuit board
> repair, so maybe it's not as big a deal to me as to a novice. Replacing
> a resistor or capacitor is isn't that difficult, especially if you have
> a Panavise (http://www.panaviseonline.com) for holding the board. The
> alternative is to make a 45 degree bend in the leads, cut them and
> solder. The drawback to this technique is that you have to do one
> component at a time.
> Richard
> http://www.pugix.com
> Graham Atkins wrote:
>> Richard,
>>> I
>>> not
>> which
>> not really
>> Graham
> You *do* need a good pair of *SHARP* cutters. There are 2 schools here.
> #1: the cheap, but buy a new pair every 6 months and toss the old ones:
> http://www.weisd.com/store2/XCE170M.php
> The Paul Schreiber, over-the-top insane cutters (stays sharp over 5 years):
> http://www.all-spec.com/1/viewitem/522N/ALLSPEC/prodinfo/i=rss
> The secret is do NOT cut into the solder on the board. Just flush cut the
> lead sticking out of the solder.
> Paul S.
> /over 1 million cuts and going.........
2009-03-02 by Scott Juskiw
> on
