Noobie needs help! No instructions to be found...
2009-02-24 by argitoth
I purchased a Full Kit Multiple from Bridechamber and it came with the panel and enough sockets. I didn't know the full kit wouldn't come with wire and instructions needed to complete the module! Obviously, because I'm a noobie, right? This will be the first module I ever put together. I'm going to assume it's the most simple module possible. I don't know the first thing about how a socket works. I don't know how a socket is oriented nor do I know what each metal arm is for. First thing's first, I need wire. What wire do you recommend? Do you have a mouser part number for it? Next thing I need to understand is how the jack is oriented and what metal arms need to be connected together. Any kind of documentation for completing a multiple would be very helpful! I didn't find it at dragonflyvalley.com. Was i not looking hard enough? Hint #1 from DragonFlyValley.com - http://www.dragonflyalley.com/images/MOTM485/485-12-jacks1A.jpg *That must be how the jacks are supposed to be oriented! Hint #2 from DragonFlyValley.com - http://www.dragonflyalley.com/images/MOTM300/300-31-syncInOut4B.jpg *When oriented like above, the diagonal arm is ground, the horizontal arm is tip, the vertical arm... no idea! But I know what it's NOT. PLEASE HELP A NOOBIE :'(
