Longer power cables?
2009-02-12 by Paul Schreiber
Does anyone see a need for longer power cables? I can make them any length,
just wondering.
Re: [motm] Longer power cables?
2009-02-12 by ach_gott@yahoo.com
Absolutely yes! A 24U cabinet gets difficult to wire sometimes.
Sent from my BlackBerry wireless handheld.
Date: Thu, 12 Feb 2009 09:31:20 -0600
To: MOTM List<motm@yahoogroups.com>
Subject: [motm] Longer power cables?
just wondering.
Re: Longer power cables?
2009-02-12 by jneilnyc
length,
> just wondering.
> Paul S.
I was able to make do with the currently available lengths in my 3-row
racks, but it did influence how and where I mounted the power
supply/breakout boards.
On a related not, how hard would it be to make the size of the
PowerOne supply optional in a 900 or 950 (or offer an "empty" module
and let you source your own PowerOnes)?  I have 2 of the stock units
sitting here from the ones I upgraded, but I probably would have just
gotten bigger ones to start with if it had been an option.  I will
probably turn one of them into a bench supply, but here again, it
would be nice to be able to order the various parts separately.
Re: [motm] Re: Longer power cables?
2009-02-12 by Scott Juskiw
I second this. I was going to plead for this as an option next time I
build more cabinets. I like the official MOTM-900 panel, but want to
use my own Power One supplies. If we can buy just the panel, switch,
and select the power distribution board, that would make my day.
2009-02-12 by John Blacet
If you want to make longer power cables DIY, Blacet offers two kits that
feature 18 ga wire and connectors, one comes with a crimper. Only
available in the 4 conductor wire and connector though.
John Blacet
RE: [motm] Longer power cables?
2009-02-12 by Tkacs, Ken
length, just wondering.
Definitely. I've bought many from you over the years -- even with four
distribution boards, almost half my modules don't seem to reach with the
stock cords. Especially not with enough slack to allow one to pull the
module forward to work on it at all.
I don't suppose anyone makes a power cable extender (or an adaptor
that would let you connect 2 cables into one long run) we could use
when we want to pull a module out like that?
2009-02-13 by George Kisslak
I think the standard 20" are too short.  The 30" is a good size.  A couple
of 3 footers would help out for those modules at the extremes of distance
from the PS.
George
> just wondering.
> Paul S.
2009-02-13 by Stephen Drake
I have a relatively large modular, 3x24u, and have never had a problem with just using the stock cables that came with the kits. I think I ordered 2 or 3 larger ones once, but that's it. I do have power distro boards in the middle of both cabinets though - this wouldn't work otherwise. So, I have no use for longer ones.
from the PS.
George
> just wondering.
> Paul S.
Stephen Drake
sduck409@...
makeme1witheverything@...
2009-02-13 by John L Rice
The 20" power cables have always worked fine for me, except for one module I
used a 30" one. I have relatively small cases though (10U wide and 12U
tall).
I was thinking that "MTA Couplers" would be handy for connecting two shorter
cables together.  I might try to make one later for fun. Just two headers
with their pins soldered together and insulated somehow. Or maybe a little
PCB . . .
John L Rice
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of Paul
Schreiber
Sent: Thursday, February 12, 2009 7:31 AM
To: MOTM List
just wondering.
2009-02-13 by djbrow54
This is what I use.  It's just a 6 pin MTA connector but the pins
extend equally long on both sides.  I just piggyback cables together
when I need an extension to work outside the cabinet.  I always check
it twice - red to red and white to white.  I don't know where I got
it - been too long.
I also have soldered back to back connectors with a break in one of
the power rails so I can measure current.  Have one for each of the
three voltages.
Dave
two shorter
headers
little
> PCB . . .
> John L Rice
