650 portamento parameter?
2008-12-10 by loopcycle
how do i adjust my basic portamento time in the 650?  i cant find it
in the menu--im only seeing the options 'constant time' and 'constant
rate'.  thanks!
Re: [motm] 650 portamento parameter?
2008-12-10 by Scott Juskiw
Look here for a chart I made that shows all the options, you need to
select either constant time or constant rate, then select an option
after that.
> rate'.  thanks!
link:
http://www.tellun.com/motm/MOTM-650_Menu_Chart.pdf
> after that.
>> rate'.  thanks!
2008-12-11 by loopcycle
excellent, thanks scott.
--- On Wed, 12/10/08, Scott Juskiw <scott@...> wrote:
> From: Scott Juskiw <scott@...>
> Subject: Re: [motm] 650 portamento parameter?
> To: "Scott Juskiw" <scott@...>
> Cc: "loopcycle" <loopcycle@...>, motm@yahoogroups.com
> Date: Wednesday, December 10, 2008, 3:53 PM
> link:
> select an option
> > after that.
> 650?  i cant find it
> >> rate'.  thanks!
2008-12-11 by Neil Bradley
> rate'.  thanks!
Portamento time is a voice group parameter, not a global parameter. This
is so you can have different timings on portamento based on voice
groupings instead of a "one size fits all" situation.
-->Neil
C. Neil Bradley - EVERYBODY KERNEL PANIC!
