OT: Compressor/Limiter/Gate
2008-12-02 by Richard Brewster
I'm wondering if a compressor/limiter/gate would improve the straight-to-MP3 recordings I make with the Tascam SS-R1. Or to improve the live sound. I'm looking at the following units. http://www.bbesound.com/products/maxcom/index.asp http://www.dbxpro.com/166XL/166XL.php I wish I could get hold of these units to play with to get a better idea of what they would do, before having to buy them. But in lieu of that, I'd appreciate any advice. TIA, Richard Brewster http://www.pugix.com <http://pugix.com>
2008-12-02 by John L Rice
Hi Richard, I can see where a limiter along with some light compression maybe could be useful for a synth, especially when doing unpredictable stuff like noise patches and patching a modular live. It would help by not letting the output to your amplifier go beyond a set level (the limiter) so that you could avoid overloads etc and the compressor is basically used to reduce dynamic range so softer sounds effectively can be heard better (the compressor has a volume threshold setting and when the input volume reaches the threshold point, it starts reducing the output volume. So, it makes the louder passages of the input sound softer and then by cranking up the output gain to the amp, the softer sounds are more easily heard at the sacrifice of some dynamics) The Sonic Maximizer is an interesting device but it's not magic (like I thought it was when I first got one! ;-) and it's hard to resist the temptation to crank up the effect just a little too much (subtle amounts are best) so running everything through it all the time tends to make people finally unplug them and not use them anymore. That said, I found that they are great for doing cassette tape to digital transfers (can brighten up dull tapes without "sounding EQ's") and I've read that they are often used for live sound systems to bring a little extra clarity or 'cut'. One of my favorite uses was to 'spruce up' a synthesized Hammond organ patch. Like the 'best' rock organ sound in a Roland MKS-50 synth through the rock organ effect on a Roland RPS-550 can sound pretty OK, but running that output into a Sonic Maximizer makes it sound almost great! (gives it just a little bit of bite that improves the sound 100%, at least to me) What is it exactly that you aren't happy with or feel you are missing from your synth/live sound? Best of luck! John L Rice PS - I have succumbed to yours, and others, greater wisdom and have realized that it will be much better (and actually necessary) to put a separate power supply in each of my portable cabinets! "You can lead synthesists to multiple power supplies but you can't get them amped up!" ;-)
-----Original Message----- From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of Richard Brewster Sent: Monday, December 01, 2008 7:16 PM To: MOTM List Subject: [motm] OT: Compressor/Limiter/Gate I'm wondering if a compressor/limiter/gate would improve the straight-to-MP3 recordings I make with the Tascam SS-R1. Or to improve the live sound. I'm looking at the following units. http://www.bbesound.com/products/maxcom/index.asp http://www.dbxpro.com/166XL/166XL.php I wish I could get hold of these units to play with to get a better idea of what they would do, before having to buy them. But in lieu of that, I'd appreciate any advice. TIA, Richard Brewster http://www.pugix.com <http://pugix.com> ------------------------------------ Yahoo! Groups Links
2008-12-02 by hearts + horses
you should look into the PRO VLA or the really nice compressor. those are suposed to be good. I know the tapeop guys are allways talking about the PRO VLA. tapeop is a recording magazine who has reviewed an MOTM filter but I cant remember which one. I think they said it was the best filter they had ever heard. go figure :) http://www.fmraudio.com/ http://www.zzounds.com/item--ART212 wes --- On Mon, 12/1/08, Richard Brewster <pugix@...> wrote:
From: Richard Brewster <pugix@...> Subject: [motm] OT: Compressor/Limiter/Gate To: "MOTM List" <motm@yahoogroups.com> Date: Monday, December 1, 2008, 7:16 PM I'm wondering if a compressor/limiter/ gate would improve the straight-to- MP3 recordings I make with the Tascam SS-R1. Or to improve the live sound. I'm looking at the following units. http://www.bbesound .com/products/ maxcom/index. asp http://www.dbxpro. com/166XL/ 166XL.php I wish I could get hold of these units to play with to get a better idea of what they would do, before having to buy them. But in lieu of that, I'd appreciate any advice. TIA, Richard Brewster http://www.pugix. com <http://pugix. com>
2008-12-02 by Jeff Laity
A compressor is just a different sound, not better or worse. It would prevent clipping if that's a problem. The BBE distorts and phases high frequencies to add them to a dull signal, I don't think you need it. I mistrust a box that claims to make anything better just by running through it. Does the sound from the SS-R1 sound different than the straight modular? I would think they are pretty close. Maybe you should add a mixer in front of the recorder. Then you would be able to control panning better, EQ and effect different parts better.
On Dec 1, 2008, at 7:16 PM, Richard Brewster wrote: > I'm wondering if a compressor/limiter/gate would improve the > straight-to-MP3 recordings I make with the Tascam SS-R1. Or to improve > the live sound. I'm looking at the following units. > > http://www.bbesound.com/products/maxcom/index.asp > > http://www.dbxpro.com/166XL/166XL.php > > I wish I could get hold of these units to play with to get a better > idea > of what they would do, before having to buy them. But in lieu of that, > I'd appreciate any advice. > > TIA, > > Richard Brewster > http://www.pugix.com <http://pugix.com> > >
2008-12-02 by John Mahoney
My posts are getting blocked. I guess they have HTML in them, despite [grumble Eudora grumble]. I assume that Richard has gotten the CCs. In short, I'd recommend the FMR RNC as an inexpensive, fairly transparent comp/limitier. As for gating, I'd rather do that in my DAW. John
2008-12-03 by Richard Brewster
I've read all the replies and thanks to everyone who responded. I wasn't clear in my original post about what I want the compressor/limiter to do. I think I was enticed by the idea of "sonic maximizer", but really I don't want another sound enhancer, so I've ruled out the BBE MaxCom. What I really want is a limiter that will let me use all the headroom of the recorder without having to worry about clipping. The sort of material I make includes unpredictable peaks. I will look at the FMR RNC. Nobody commented about the DBX 166XL. I'm still considering that and maybe the 266XL. I have been using the Tascam SS-R1 to record direct to MP3 at 192K BPS. I use a Mackie 802-VLZ3 mixer between the synthesizer and the recorder. http://pugix.com/synth/overview/ The results sound pretty good to my ears. All of the recent MP3s posted on my website have been recorded this way. Most of these were spur-of-the-moment recordings. In the future I may try recording in WAV format and use external software of some kind for editing and exporting to MP3. A limiter would help in that scenario to get the maximum dynamic range without clipping in the original recording. Again, thanks for all the replies. Richard Brewster John Mahoney wrote:
> My posts are getting blocked. I guess they have HTML in them, despite > [grumble Eudora grumble]. I assume that Richard has gotten the CCs. > > In short, I'd recommend the FMR RNC as an inexpensive, fairly > transparent comp/limitier. > > As for gating, I'd rather do that in my DAW. > > John > >
2008-12-03 by John Mahoney
At 08:01 PM 12/2/2008, Richard Brewster wrote: >I've read all the replies and thanks to everyone who responded. I >wasn't clear in my original post about what I want the >compressor/limiter to do. I think I was enticed by the idea of "sonic >maximizer", but really I don't want another sound enhancer, so I've >ruled out the BBE MaxCom. What I really want is a limiter that will let >me use all the headroom of the recorder without having to worry about >clipping. The sort of material I make includes unpredictable peaks. Based on my admittedly limited experience, that is definitely what you want! > I >will look at the FMR RNC. Nobody commented about the DBX 166XL. I'm >still considering that and maybe the 266XL. I've got a 266, too. Got it on sale and used it once or twice for recording bass to tape (to boost quiet parts above the tape noise). The RNC is cleaner, less colored, definitely better for recording a mix. The 166 is popular. I may eventually get around to selling my 266; if so, I may get a 166. But I'd be using it for tracking (recording individual instruments), not for limiting a 2-track mix, not when I've got the RNC. :-) No comment on the ART Pro VLA, as I've never seen or used one. ART does offer good price:performance, on the whole. John
Thanks for the additional tips. Everyone seems to have good things to say about the FMR RNC. I think I'm going to get one of those. It will patch right into the inserts on my Mackie 802-VLZ3 mixer. I'll look into the Aphex Dominator too. Another funny name for my wife to kid me about. About the FMC, "Yeah, and it really has a button that says "Super Nice". I think she's hoping I'll get that kind of button. Richard jneilnyc wrote:
> --- In motm@yahoogroups.com, Richard Brewster <pugix@...> wrote: > >> I've read all the replies and thanks to everyone who responded. I >> wasn't clear in my original post about what I want the >> compressor/limiter to do. I think I was enticed by the idea of "sonic >> maximizer", but really I don't want another sound enhancer, so I've >> ruled out the BBE MaxCom. What I really want is a limiter that will >> > let > >> me use all the headroom of the recorder without having to worry about >> clipping. The sort of material I make includes unpredictable peaks. I >> will look at the FMR RNC. Nobody commented about the DBX 166XL. I'm >> still considering that and maybe the 266XL. >> > > I have the Pro VLA, and it's a nice cheap box that adds a little > warmth but also seems to make the track a little softer and more > textured. Sometimes this is exactly what you want, other times not. > > The RNC on the other hand is very transparent, and if you set it up > right it can serve to flatten out unwanted transients without > significantly changing the perceived tone. > > Even if you do get a compressor like one of those, you might want to > keep a lookout for a used Aphex Dominator. It's a limiter that I used > a lot in tracking for the reasons you suggest, to be able to keep > levels up without having to worry about a spike getting through and > ruining a track with digital distortion. These weren't cheap, but > there are a dozen of them on ebay right now, and they appear to be > selling in the $250-$500 range. > > http://www.aphex.com/720_722.htm > > > > >
2008-12-03 by Jeff Laity
Another one to consider is the stereo compressor from Chameleon Labs. It's modeled on the SSL Mix Buss compressor, which has been used to make records "punchy" for the last 25 years. It's affordable and has gotten great reviews from Tape Op and others. http://www.chameleonlabs.com/product5.html It's also hard to go wrong with the DBX, the 166 has been around forever. On Dec 3, 2008, at 3:44 PM, Richard Brewster wrote: > Thanks for the additional tips. Everyone seems to have good things to > say about the FMR RNC. I think I'm going to get one of those. It will > patch right into the inserts on my Mackie 802-VLZ3 mixer. I'll look > into the Aphex Dominator too. Another funny name for my wife to kid me > about. About the FMC, "Yeah, and it really has a button that says > "Super Nice". I think she's hoping I'll get that kind of button. > > Richard > > jneilnyc wrote: > > --- In motm@yahoogroups.com, Richard Brewster <pugix@...> wrote: > > > >> I've read all the replies and thanks to everyone who responded. I > >> wasn't clear in my original post about what I want the > >> compressor/limiter to do. I think I was enticed by the idea of > "sonic > >> maximizer", but really I don't want another sound enhancer, so I've > >> ruled out the BBE MaxCom. What I really want is a limiter that will > >> > > let > > > >> me use all the headroom of the recorder without having to worry > about > >> clipping. The sort of material I make includes unpredictable > peaks. I > >> will look at the FMR RNC. Nobody commented about the DBX 166XL. I'm > >> still considering that and maybe the 266XL. > >> > > > > I have the Pro VLA, and it's a nice cheap box that adds a little > > warmth but also seems to make the track a little softer and more > > textured. Sometimes this is exactly what you want, other times not. > > > > The RNC on the other hand is very transparent, and if you set it up > > right it can serve to flatten out unwanted transients without > > significantly changing the perceived tone. > > > > Even if you do get a compressor like one of those, you might want to > > keep a lookout for a used Aphex Dominator. It's a limiter that I > used > > a lot in tracking for the reasons you suggest, to be able to keep > > levels up without having to worry about a spike getting through and > > ruining a track with digital distortion. These weren't cheap, but > > there are a dozen of them on ebay right now, and they appear to be > > selling in the $250-$500 range. > > > > http://www.aphex.com/720_722.htm > > > > > > > > > > > NOTICE: This electronic mail message and its contents, including any attachments hereto (collectively, "this e-mail"), is hereby designated as "confidential and proprietary." This e-mail\ufffdmay be viewed and used only by the person to whom it has been sent and his/her employer\ufffdsolely for the express purpose for which it has been disclosed and only in\ufffdaccordance with any confidentiality or non-disclosure (or similar) agreement between TEAC Corporation or its affiliates and said employer, and may not be disclosed to any other person or entity. \ufffd \ufffd \ufffd
2008-12-05 by Richard Brewster
Thanks for the tip, John. I have purchased from BSW before and they have excellent customer service. I've been having fun researching compressors and decided to go all out and get two FMR RNC units and this rack panel to hold them: http://www.funklogic.com/NCC-1701.htm I found this deal: http://www.humbuckermusic.com/dualrnccomwi1.html $379 for everything and free shipping. Yippee! Comparing this dual RNC setup to the dbx 166XL or 266XL, I'm getting four channels of compression in the same rack space as I would get two channels with a standard dual compressor. And I always get two of everything, right? This will give me a lot of flexibility. I've already planned how to patch these into my gear. One RNC will patch into the inserts of the two input channels on my mixer, so I get compression coming in. The other RNC will patch between my mixer outputs and the recorder inputs. I'll be able to use either or both compressors. I have an idea to try patching the side chain on the input compressor through various MOTM filters for special effects. I hope you don't mind my copying this reply back to the MOTM list. My search is over and it was all very educational. I thank everyone who contributed to my education! Richard Brewster http://www.pugix.com John L Rice wrote:
> Hi Richard, > > I know you are planning on the FMR RNC now (and I've always heard that those > are a impressive units!) but I was this today and thought of you so I'm > passing it along FWIW: > DBX 266XL-BSTOCK $109.95 > http://www.bswusa.com/proditem.asp?item=266XL-BSTOCK > > John L Rice >
2008-12-05 by John Mahoney
Uh oh... It's a little late to mention this, but it's important to note that the FMR RNC is a stereo unit. It's not a dual mono unit with a link function. In that regard, it's unlike the DBX 166, 266, and most others. Only one set of controls for both channels, that's why it's so small! Sorry that I forgot to mention this earlier. For whatever reason, I thought you just wanted a comp/limiter on a stereo buss. John
If I would have read your whole post, I'd have seen that stereo operation is what you need. Over and out on this OT talk, John
