More Potentiometer questions - Guitar apps.
2000-01-07 by Mark T
Hey Paul & group,
Speaking of potentiometers,
I was going to ask your opinions on replacing a scratchy volume & tone pot
on my Fender bass (57' Re-Issue.For this application, should I go with a
Spectrol or a Bourns? Audio or Linear taper?  How many K?
I recall reading that the higher Ohmage ( is that a word?) would bleed off
some top end to ground.. I'd appreciate your opinions/ suggestions.
Mark
Re: More Potentiometer questions - Guitar apps.
2000-01-07 by Paul Schreiber
I was in a Mars Music last week, and in the Guitar section there was a *wall
full* of replacement
parts for Fender and Gibson guitars. Looked like a Pep Boys.
Also try: www.guitarparts.com
To: <motm@onelist.com>
Sent: Thursday, January 06, 2000 11:07 PM
Subject: [motm] More Potentiometer questions - Guitar apps.
> Hey Paul & group,
> Regards,
> Mark
> --------------------------- ONElist Sponsor ----------------------------
>     GRAB THE GATOR! FREE SOFTWARE DOES ALL THE TYPING FOR YOU!
> Tired of filling out forms and remembering passwords? Gator fills in
> forms and passwords with just one click! Comes with $50 in free coupons!
>   <a href=" http://clickme.onelist.com/ad/gator4 ">Click Here</a>
2000-01-08 by thebass
cts 250k  you can get it from Allparts
JWBarlow@... wrote:
> From: JWBarlow@...
> In a message dated 1/6/2000 10:38:37 PM, mmt@... writes:
> >pot
> >a
> >off
> I looked in some of my books and was surprised that wiring diagrams for both
> J and P basses showed no values for pots or caps -- that's the problem with
> today's guitar manufacturers, no values!
> What I can tell you is that you want an audio taper and I'm reasonably sure
> you want a 250K value (the other popular value is 500K). The value is almost
> certainly stamped on the case of the pot, so take a look at what's in it
> before going ahead. I'd try spraying the old pots out with Deoxit first, but
> you can get the parts from the place Paul recommended, or (my fave) Stewart
> Macdonald's Guitar Shop Supply (www.stewmac.com). These pots are listed for
> less than $3.00, of course they won't be as good as the Spectrol pots, but
> they are the right parts for the job.
> BTW, it's the 250K pots that bleed off the high end to ground and are said to
> have a more beefy (warmer) tone. Humbucking PUs usually use 500K pots while
> Strats and Teles generally have 250K pots -- think how much more zing they'd
> have if they used 500K pots!
> Hope this helps you!
> JB
> Get great offers on top-notch products that match your interests!
> Sign up for eLerts at:
> <a href=" http://clickme.onelist.com/ad/elerts1 ">Click Here</a>
2000-01-08 by JWBarlow@xxx.xxx
>pot
>a
>off
JB
