Re: [sdiy] Subtle Chorus (including Dimension D emulation)
2008-07-26 by JH.
>The BBD board needs 2 x MN3007 and 2 x MN3101. These are quite easy to get, >compared to other vintage BBDs. Forgot to mention: BBD board also needs 2 x NE570 (or NE571, or SA571) companders. JH.
----- Original Message ----- From: "JH." <jhaible@...> To: <synth-diy@...>; "analog heaven" <analogue@...>; "MOTM List" <motm@yahoogroups.com> Sent: Saturday, July 26, 2008 10:45 AM Subject: [sdiy] Subtle Chorus (including Dimension D emulation) Hi, just wanted to give you a quick update of my upcoming (fall 2008) "Subtle Chorus" PCB project, which, among other things, will be able to emulate a Dimension D, (using original ICs and all), plus "Dim T" (Same topology but with two 20-stage phasers instead of BBDs), plus generic true-stereo, dual-BBD chorus. Depending on what configuration you want, this will use one, or up to four PCBs. (Dim D emulation needs two PCBs.) The "Subtle Chorus" is a variable project consisting of 3 different PCBs that can be combined for various functions. a.. You can build a rather simple, true-stereo, dual-BBD Chorus with voltage controlled Chorus Rate and voltage controlled Chorus Depth, using a single PCB. b.. You can emulate the famous "Dimension D" (Trademark of Roland / Boss) sound with it's unique filtering and presets, using two PCBs, the "Dim D" (You even have the choice between vintage HA1457W opamps, or more common TL071 / TL072 opamps.) c.. You can build a similar effect that uses 20-pole all pass filters instead of BBDs, using three PCBs, the "Dim T". d.. And you can build an overkill effect device that allows to choose between the Dim D and Dim T effect, using 4 PCBs, the "Dim TD" version. So far, the BBD board design is finished; main board will be the next. Documentation is here: http://www.jhaible.heim.at/subtle_chorus/jh_subtle_chorus.html The BBD board needs 2 x MN3007 and 2 x MN3101. These are quite easy to get, compared to other vintage BBDs. The Dim T version doesn't need any BBDs, of course. JH. _______________________________________________ Synth-diy mailing list Synth-diy@... http://dropmix.xs4all.nl/mailman/listinfo/synth-diy
