Fuse part number form MOTM-900/950
2008-07-05 by Richard Brewster
Looking at Mouser for replacement 800ma/250V SLO-BLO 5mm x 20mm fuse, I
see three choices (current catalog page 591): Series 215, 218, and 239.
Which is the correct part.  And what's the difference, besides cost
($1.23, $1.99, and $0.75 in single quantity, respectively)?
I haven't blown a fuse.  Just looking for similar parts.
Richard Brewster
http://www.pugix.com
Re: [motm] Fuse part number form MOTM-900/950
2008-07-05 by Paul Schreiber
215 = ceramic fuse body (not glass) used in high shock/vibe will work but
overkill
218 = 'normal' fuse for Europe, what I buy
239 = 'normal' fuse for USA, what I buy
To: "MOTM List" <motm@yahoogroups.com>
Sent: Saturday, July 05, 2008 12:08 PM
Subject: [motm] Fuse part number form MOTM-900/950
> Thanks,
> Richard Brewster
Re: Fuse part number form MOTM-900/950
2008-12-14 by jneilnyc
I'm trying to confirm which fuse to get for a 900 upgraded with a
HBB15-1.5A power supply.
The unit itself seems to suggest a 1 amp verion of the 239 would work
for 110VAC.  The printed instructions, however, seem to say to use a
.5 (assuming I'm reading it right).  Both of these seem low to this
admittedly non-electronics-geek, so I thought I'd ask here, since I
know some of you have done this upgrade.
Thanks!
JN
work but
> overkill
> Paul S.
> From: "Richard Brewster" <pugix@...>
fuse, I
239.
> > Thanks,
> > Richard Brewster
> > Yahoo! Groups Links
Re: [motm] Re: Fuse part number form MOTM-900/950
2008-12-14 by Paul Schreiber
a) you need to use the value printed on the supply, for the proper *input
voltage*. The 110 & 220V fuses will differ by 1/2.
b) you need to use Slo-Blo types if possible. Fuses are 5mm X 20mm (standard
size).
c) since you are fusing the AC input side, that current will be lower than
the output side (which is a lower *voltage*).
