More MOTM/Moog comparisons
2000-01-03 by Eric S. Crawley
So, here are my very subjective assessments of the MOTM 320 VCF compared to the R.A. Moog 904A VCF. Again, these are very different beasts. The Moog is a 24db/oct filter while the MOTM is a 12db/oct filter. The Moog filter does not overload as easily as the MOTM and does not have a built-in reversable attenuator (although one is available on the standard Filter control panel). I was quite suprised at how similar I could get these two filters to sound with low level inputs. I just used the sawtooth output of the MOTM 300 as input to both filters. With no resonance on either filter, the difference between the slopes was evident though. I could hear more harmonics coming through on the MOTM. Both filters seemed to have non-linearities as the resonance was cranked. I can't quite describe the character of each in words but both were very cool sounding. I guess the best description of the difference between the two is that the Moog filter is naturally darker because of the sharper slope. As the input level increased, both overloaded in neat ways. I think the Moog was a bit more "throaty" at higher resonances with a bit more of a vocal formant sound while the MOTM was more "fuzzy" at similar resonance levels (great subjective terms, eh?). Maybe another way of describing the difference was that the MOTM sounded more "muscular" than the Moog when overloaded. Again, both were very musically useful and interesting. I tried using a sample & hold with a slow sawtooth input on both filters to get them jumping around the frequencies to hear differences. I was again surprised at the similar sound I could get out of the MOTM at low input levels. The Moog sounded a tad bit better in this situation wtih the resonance cranked getting just a bit more of the classic strong "beeoow" sweep sound. I think both filters can be quite agressive sounding with overloaded inputs with the MOTM having a generally stronger agressive sound (aka MS-20 like) while the Moog has more of a classic sound. I don't know if this helps anyone out there but I couldn't think of any way to compare these two filters scientifically or even objectively! If anyone has some ideas, I'd be happy to try them. I've certainly learned a lot doing these comparisons. BTW, I found out what was happening with my sawtooth tests when mixing the MOTM and Moog saw waves together. The MOTM 300 has a downward sawtooth wave while the Moog has an rising sawtooth wave. When mixed together, they produce something like a pulse wave and as their phases/pitches change, a form of PWM occurs. I watched this on an ancient Heathkit scope, it was quite interesting! I changed the phase of the MOTM oscillator (Moog mixer panels have both + and - outputs; hint, hint Paul) and lo, the summed wave looked more sawtooth shaped. I like the Saw-Width-Modulation that came out of this and will use it in the future! It is different than the traditional PWM sound. Eric
