Re: [motm] Elhardt gets his wish - and Acoustic Piano Tones
2008-06-04 by Kenneth Elhardt
Les Mizzell writes: >>What are you waiting on? Just do it. You *have* the programming and performance chops and you know it!<< Well I still plan on it, but I'm not in the business, others are, but aren't doing anything. However, that's a bit like telling a magician to videotape himself performing a magic act and then play it back so he can watch himself. I expect to hear synth music from others, as I'm already familiar with my own stuff that would go onto a CD. BTW I hope nobody got the impression that I was saying the new Bhatia CD was no good. I may well be interesting in itself and very well done. It just isn't really a synth CD, nor satisfy the 2.5+ decade synthesis vacancy left by synthesists like Tomita or Carlos. Since I just uploaded this to another forum, might as well to this dead list too. It's an attempt to get acoustic piano tones out of a simple synth, in this case a Multimoog (could be just about any simple synth) and in this case a cheap Behringer Virtualizer multi-effects unit. It was sampled into an E4K to be played. It's got lots of problems and is a bit quirky, but I may be able to port the idea to Reaktor and solve the problems and improve it for actual use. This is part of a bunch of new concepts I've come up with to use outboard effects to generate sophisticated and complex sounds from the simplest and cheesiest synth tones fed into them. Three different piano tones in this short demo: http://home.att.net/~elhardt3/Multimoog_Virtualizer_Piano.mp3 -Elhardt
