OT capacitor question
2008-05-30 by Mark
I'm looking for axial polypropylene caps.  More specifically, I'm
looking to buy small quantities of 400V caps in smallish values such
as 20nF, 50nF, 100nF, 220nF, etc. I checked Mouser, Digi-Key, Allied,
and Newark.  Antique Electronic Supply sells Illinois Capacitor's MPW
series in 630V values, but they don't sell their 400V caps.  While
I've found a number of radial caps, it seems all the axial film caps
are either outrageously expensive, not available in the right values,
or both.  Any ideas??
Re: [motm] OT capacitor question
2008-05-30 by Mark
On 5/30/08, Paul Schreiber put forth:
>a) a 630V cap will work in a 400V application
This is true, and I might end up doing that, but they are also larger
and more expensive.
I've read that electrolytic caps don't work as well when the voltage
rating is much higher than necessary, but I have no idea about film
caps.  The plate voltages are all around 200V, but all the original
film caps were 400V, even in the passive filters where the voltages
are relatively low.
>b) if this is for speaker crossovers/amps, try Old Colony Sound Labs
It's for an old tube pre-amp.  Thanks, I just looked there, and it doesn't
look like they sell capacitors.
