MOTM road cases?
MOTM road cases?
2008-05-10 by Richard Brewster
I am wondering if anyone can show me an example of using MOTM rack rails
to mount modules in a rack that can be ported around.  I have looked at
typical 19-inch road cabinets and found that most of them are either too
deep or too short to be well suited.  A 12-inch depth should be adequate
for any module, even with Stooge long brackets.  Ideally I would like to
have three 10U wide rows of 5U height modules.  That would be a tall
case, about 30 inches.  I am thinking of using a second road case for my
Mackie 802-VLZ3 mixer and three 1U height pieces of equipment (MPX-1,
flash recorder, and power conditioner).  I would consider going with two
two-tier cabinets of 10U width.  My studio has 130U of modules, and I'd
like to be able to take at 30 to 40U with me.  20U would be a bit austere.
Any suggestions appreciated.
TIA,
Richard Brewster
http://www.pugix.com
Re: MOTM road cases?
2008-05-11 by Ivan
The taller the rack the deeper it needs to be in order to be stable
when standing.  I had R&R Cases build some 12" deep 19" wood racks in
a case for my MOTM setup.  R&R is expensive but build the finest
touring case that I know of (I've used them for $250,000 mixing consoles):
http://www.rrcases.com/rackwoodcommon.htm
If you stayed with normal 19" cases you could go with a bunch of
10-space racks.  EWI has the best inexensive (made in Korea) cases for
the money that are shallow enough for MOTM:
http://tinyurl.com/5us84t
They also have 6-space racks and if you don't want the shallowest 10"
deep case they do have a 12" deep version.
Here are the R&R racks that I had built (they fit into ATA cases for
transport):
http://HOME1.GTE.NET/res05k5t/pics/MOTMracks1.jpg
http://HOME1.GTE.NET/res05k5t/pics/MOTMracks2.jpg
18mm 13-ply Baltic Birch plywood. Both are 11-spaces and have a door
on the rear.
Ivan
rails
too
adequate
like to
for my
two
Re: [motm] Re: MOTM road cases?
2008-05-11 by Richard Brewster
I'm leaning towards two standard 10U cases.  Ivan, how do you power the
R&R cases?
-Richard
> transport):
> on the rear.
> Ivan
> rails
> too
> adequate
> like to
> for my
> two
2008-05-11 by Ivan
I use Hubbell chassis-mount twistlock connectors mounted on the back
panel.  You can also use the Neutrik PowerCon connector.
Ivan
> R&R cases?
2008-05-11 by Ivan
Use the blue ones:
http://www.redco.com/shopdisplayproducts.asp?id=50&cat=Powercon+Connectors
> Ivan
power the
> > R&R cases?
