MOTM-850 Pedal Interface
2008-04-07 by Robert Holmström
Anyone got a a MOTM-850 pedal interface lying around? Or maybe just a PCB?
Or does anyone know of a similar product out there (could be DIY project)?
Thanks!
Robert
Re: [motm] MOTM-850 Pedal Interface
2008-04-07 by Mark
On 4/7/08, Robert Holmström put forth:
A pedal is a pot wired as a voltage divider.  Typically, the wiper of
the pot is connected to the ring of the plug, and the jack is wired
like this:
tip -- voltage in
ring -- constant voltage out
sleeve -- ground
I don't know what the difference is between the Roland and Yamaha
pedals to which the MOTM-850 description refers.
While the 850 does have a number of features, if you had a panel, it
wouldn't be too difficult to build your own using a MUUB or project
board using a few op amps.  It looks like the "Range" function could
be duplicated by controlling the voltage going to the pedal, and the
output from the pedal is summed with the outputs of "Mix" and
"Offset".  The gate feature is likely a comparator that looks at the
pot and pedal output.
2008-04-08 by Mark
Woops!!  I meant to write that the the wiper of the pot is connected
to the tip of the plug, not the ring.
>like this:
>tip -- voltage in
>sleeve -- ground
Re: Re: [motm] MOTM-850 Pedal Interface
2008-04-08 by synth1@airmail.net
I have ~ 10 of the pc boards I can put into the cart, but NO panels.
Msg sent via Internet America Webmail - www.internetamerica.com
