Index last updated: 2026-03-30 17:37 UTC
Modular Compatibility (MOTM, Oakley, Modcan B)
2008-03-30 by mathroutine
Hello all. I just wanted to verify that all these formats are
compatible. If I pick up a set of MOTM rack rails, and an MOTM 900
power supply, I will be able to power various modules from MOTM,
Oakely, and Modcan B, correct? Is there anything I need to be aware of?
Thanks in advance.
Re: [motm] Modular Compatibility (MOTM, Oakley, Modcan B)
2008-03-30 by eric f
You'll be fine. The only thing to keep in mind is that when you order the Modcan, you need to ask Bruce for the Modan to MOTM cable (MOTM distro board has 2 grounds, Modcan just one, but otherwise they're equivalent).
cheers,
eric f
Thanks in advance.
2008-03-30 by Stephen Drake
I run blacet, MFOS and a few diy modules straight off the motm power supply. In the past I used to also run synthesizer.com modules too, but you need the little adapter they sell to do that. I know you weren't asking about any of these brands, but in case you wanted to know more for the future...
cheers,
eric f
Thanks in advance.
Stephen Drake
sduck409@...
makeme1witheverything@...
2008-03-30 by Richard Brewster
I have three Modcan B series modules in my MOTM rack.
http://pugix.com/synth/category/modules/modcan/
Two of these, the CV Recorder and the VCDO, have a 200ma draw from the
+15V supply in the standard build. On-board regulator generates +5V
from the +15 supply. But Bruce Duncan is happy to build these with a
5-pin power connector, so that +5V can be supplied externally. He
delivered the modules with 5-pin connectors and cables with bare ends.
I put 6-pin connectors on the bare ends to mate with the MOTM-950, and
life is good. The Dual Quantizer board can also be assembled to use
external +5V. But since the +15 current is only 45ma (as specified; I
haven't measured it), that one uses the normal 3- to 4-pin adapter
cable. (Modcan B has a 3-pin power connector for +/-15V and ground.)
Just make sure to order the right cables and build method for your Modcan.
Oakley power connection are compatible with MOTM. The only difference
is that the two center pins are not connected to each other on Oakley PC
boards. One is for panel ground, the other for circuit ground. In
practice this doesn't make much difference, since the two grounds are
joined at the power supply in a MOTM system.
Richard Brewster
> Thanks in advance.
