Full list of CGX controls/details
2008-03-27 by Paul Schreiber
* Processor is an ARM 32-bit Atmel AT91SAM7S64, running around 48Mhz. 64K Flash, 16K RAM. In comparison, the MOTM-650 uses an 8-bit 8051 type with 32K Flash, 1K RAM and runs at 2Mhz. * 6 24-detent rotary encoders (ALPS EC12E2420801, available from Mouser) * 1ea Crystalfontz CFAH2004A-YTI-JP LCD, reverse, 4 lines x 20char * the knobs are custom Rogan double-shot "soft touch" with white endcaps, ~0.75 diameter. The ALPS encoders have a 'D' shaft. * 1ea USB 'B' type jack (runs low speed USB 1.1). If the CGX needs a firmware update, there is a jumper setting on the rear pc board, and new code can be flashed in. * 3ea NKK JF15 series tact switches, ENTER (blue) and PG UP/PG DWN (grey or green, have not decided). These are larger than the MOTM-650 NKK switches. They are ~ 0.68" square and have a nice 'click' to them. * 5 Expansion jacks, comprising: SAW OUT TRI OUT CHAOS CV OUT - user defined DC voltage that is 'mapped' to one particular ChaosEngine element. So it's a wiggley voltage :) PATCH SEL IN - when a jack is inserted, a negative voltage reduces the current patch # and a positive voltage increases the current patch #. -5V will be mapped to Patch #1, and +5V will be Patch #16 and intermediate voltages mapped accordingly. AUX CV IN - a user defined CV input that can modulate a CG parameter, ie it has the same effect as 'turning the encoder knob' of that parameter. Mapped to -5V is minimum, +5V maximum, intermediate voltages mapped accordingly. 3U wide module. Paul S.
