Paul's Syntech brand?
2008-02-25 by LD
I own a 17" analog color tv brand name 'SYNTECH' (I am not making this up!), Obviously manufactured by Paul. I found it at the salvation army thrift store here for $10.. It has a lousy analog tuner, that easily overloads when i feed it tv signals from my Philips 46db gain amplified rabbit ears, when I set the gain at anything over 10%! Fortuantely the best buy DTV/analog tv converter box I just bought solves this problem. Further this tv evidently uses non standard IR remote control codes, that are not available with any IR universal remote I know of! Still the converter IR control still will change ch and volume..I can not program it however to turn the set on and off.. Paul what other consumer electronic devices do you manufacture under your Syntech brand name? Are the rest as mediocre as my tv set, ha! Are you ashamed to list them on the MOTM web site?
