MOTM-520 Cloud Generator additional demos
2008-02-25 by Paul Schreiber
>I have added 3 new MOTM-520 Cloud Generator demos that use the Phase Offset >registers (the last bit of FPGA code needed to basically complete the audio >portion of the feature set). > > They (and all the others if you have not heard them) are located here: > > www.synthtech.com/m520 > > the 3 new files are cg_phase_1, cg_phase_2 and cg_phase-synced > > These are short snippets showing manual Phase Offset (via twisting panel > knob), using sawtooths waves (all 16 of them) set to random initial phase, > random phase + some frequency spread, and in-phase (respectively). > > The hardware design is undergoing final design review this month before I > start pcb layout and final beta testing before production runs. Since > there are 2 sets of firmware (ARM CPU and Xilinx FPGA) we want to be sure > it is tested to minimize the need for a bug fix (the code is field > upgradeable, but not without some 'hassle'). > > Paul Schreiber > Synthesis Technology > > > >
