Re: OT--mic cables
Re: OT--mic cables
1999-12-28 by hodad1@mindspring.com
Just a dumb question:
I want to build my own mic cables, & I was looking at a Neutrik XLR jack, &
it  had three
"lugs" (whatever you call those things) arranged in the middle of the plug,
& then on the outside
edge there was a regular lug.  So do I wire to the lug on the outside edge,
& if so what?
Daring to be stupid
tomr
Re: OT--mic cables
1999-12-28 by Cary Roberts
pin 1 - GND
pin 2 - hot
pin 3 - cold
chassis ground - unconnected
-Cary
Re: OT--mic cables
1999-12-28 by Paul & Alleyne
>From: hodad1@...
forget the lug, just solder the three middle pins - if you look carefully on
the plastic housing you'll find the pins are numbered
pin 1 - screen - the braided, or lapped bit
pin 2 - we in the uk call it hot - solder the red inner cable to this (in
phase signal)
pin 3 - again, we call this cold - solder the other inner cable to this (out
of phase signal)
so long as you follow this exact scheme at the other end of the cable you'll
be laughing
cheers
paul b
