JH FS-1A Frequency Shifter Project update
2008-01-27 by JH.
Time for an update on the Frequency Shifter project. I finally found the time to draw schematics for the main board of the FS-1A (second board will follow), and I have also created a second version of the component overlay, which shows the reference designators instead of the component values. A few people have adressed me about this: That printing component values makes soldering the board easier, but debugging more difficult. And I learned the hard way that it also makes a description of adjustment procedures so much more difficult. (I've started adjustment descriptions on my FS-1A page, and had to use a lot of screenshots.) So, my solution for this, and all future projects is this: (1) Silkscreened on the board will be the component values, just as before. It makes it so much easier to put the right components on board for soldering them. And when the components are soldered in, most of these labels will not be visible anymore, anyway, as they are now beneath the components. (2) In addition to this, I'll provide a PDF with the board layout, using reference designators. You print this on paper, and have it available when you're working on your board for adjustments or debugging. See my updated FS-1A page for details: http://www.jhaible.heim.at/fs1a/fs1a.html JH.
