MOTM versus Eurorack comparison
2007-12-07 by Jeff Laity
I wrote this up on another site, thought it might be of interest here:
I had pretty much decided to put together a Euro modular, but digging
up pics and demos of my old MOTM synth made me a bit misty. I decided
to make an apples-to-apples comparison of a similar MOTM and Euro
modular. The system I designed had three oscillators, one with less
features, two voltage-controlled LFOs, one SSM-based VCF, at least two
envelopes and two VCAs.
The MOTM system ended up with two 300 oscillators, one 310 mini-
Oscillator, a 390 dual LFO, a 440 VCF, a 190 dual VCA and two 800
envelopes. This is very similar to the system I used to have. I priced
out an assembled system, and estimated what a DIY system woud cost
(using the same high-end components that SynthTech uses).
The Euro system had two Plan B model 15 VCOs, a Doepfer 110 standard
VCO, two Doepfer 147 VC LFOs, a Doepfer 105 SSM filter, a 130 dual VCA
and a 143-2 quad envelope.
I also put together a Frac system for comparison, using mostly MOTM
components: two 1300 oscillators, one 1190 dual VCA and two 1800
envelopes. I added Blacet modules: two mini LFOs and a Final Filter. I
couldn't find a "mini" VCO to compare, so I threw in a MiniWave for
the heck of it.
Here's what I came up with.
Cost:
MOTM Assembled: $2,532
MOTM DIY: $2,202
Frac: $1,883
Euro: $1,507
As expected, the Doepfer modules help in the cost category, coming in
40% below assembled MOTM and 32% below DIY modules. One of the
advantages of the Euro format is that you can combine low-cost Doepfer
modules for less-critical components like LFO and Envelopes with
higher-quality filters and oscillators. Frac comes in 25% less than
assembled modules and 14% below DIY.
A more-fair comparison would put together the DIY MOTM modules with
lower-quality pots and unsealed jacks like other modulars use, then
the cost would be nearly the same. But the result wouldn't be a MOTM
synth, would it?
Size:
MOTM: 19" x 8.75"
Euro: 20" x 6"
This was a surprise to me, I expected the MOTM to be much larger than
the Euro system. However, the size of the MOTM format allows multiple
functions to be combined into one while still leaving room for your
fat little fingers. I didn't calculate the Frac size but expect it to
be in the same ballpark.
Working on a full-size modular and a smaller size is a different
experience as well. But there are other benefits to the MOTM standard
as well, like all of the jacks on the bottom and knobs on top, that
make it easier to work with.
Must-Have Modules:
MOTM: MOTM 440
Frac: Blacet MiniWave
Euro: Plan B Model 12, 15
This is very personal, of course. I tried to come up with modules that
I wouldn't be able to get in other formats. Of course, there are MOTM
panels for almost any module, including the MiniWave but not the Plan
B (yet). Euro and Frac modules can be easily adapted for MOTM, but not
the other way around.
DIY:
MOTM: lots
Frac: some
Euro: not
There's a big DIY community for MOTM format modules, including
Bridechamber panels, several websites dedicated to converting and
designing modules, and even minimal kits from Synthtech. There's a
much smaller amount of this for Frac and almost nothing for Euro
(though I haven't researched this as much). DIY is a great way to get
more for less, as the components are not that difficult to put
together, and you get a system that you literally built yourself.
Conclusion:
It looks like I'm trying to talk myself into a MOTM system again.
Ironically, my 1/8" cables arrived yesterday. It looks like I might be
putting them on the for sale board....
NOTICE: This electronic mail message and its contents, including any attachments hereto (collectively, "this e-mail"), is hereby designated as "confidential and proprietary." This e-mail\ufffdmay be viewed and used only by the person to whom it has been sent and his/her employer\ufffdsolely for the express purpose for which it has been disclosed and only in\ufffdaccordance with any confidentiality or non-disclosure (or similar) agreement between TEAC Corporation or its affiliates and said employer, and may not be disclosed to any other person or entity. \ufffd
\ufffd
\ufffd
