Index last updated: 2026-04-03 18:09 UTC
FW: [motm] Re: [AH] Voltage controlled version of Moog Parametric EQ circuit?
2007-12-02 by Tkacs, Ken
You just described a VC parametric equalizer.
From: motm@yahoogroups.com on behalf of Seth Elgart
Sent: Sun 12/2/2007 10:30 AM
To: analogue@...; MOTM List
Subject: [motm] Re: [AH] Voltage controlled version of Moog Parametric EQ circuit?
At 8:20 AM +0100 11/30/07, JH. wrote:
>So why not design something that is even better than the original, while
>still preserving the original's behaviour?
>This leads to the voltage controlled M-Para-EQ.
Hmmmm. Wouldn't that naturally lead to the UN-fixed filter bank? What
about a voltage-controlled "fixed" filter bank. It would have all
eight bands of the fixed filter bank, but have the frequencies and
maybe resonance of each be voltage controllable. It would end up
being a pretty big module, what with all the pots and jacks, but
think of the motion you could give to a sound with one of those!
        Seth
