Turret posts
Turret posts
2007-11-02 by clickmrmike
Anyone know where I can find the tiny turret posts used in the MOTM-320?
Thanks!
mrmike
Re: [motm] Turret posts
2007-11-06 by Mark
I have no idea.  Although I do not think they are necessary.  None of
the later MOTM modules that have LED's use turret posts, and I don't
see a problem with soldering the wires directly to the PCB.
That being said, I would also like to know where to get turret posts
or something similar, but not for a Synthesis Technology module.  I
had originally planned to use bullet connectors to attach the pencil
tube in the CGS Tube VCA, but I now that I've looked into it further,
it doesn't seem like that would be stiff enough to hold the tube in
place.  The reason I do not want to solder the tube directly to the
PCB is that the tube will have to be replaced eventually, and
desoldering the old tube could damage the PCB.  Any ideas??
On 11/2/07, clickmrmike put forth:
