funny problem with s&h module
2007-10-01 by loopcycle
when i screw all four corners down to my stooge rails, the s&h does not sample.
it just holds. if i tap on the front panel with my finger, it samples the
input in time with my fingertaps.
i thought this was cool for about 5 minutes, but now i want it to work right
again.
if i take a couple screws out, the s&h works normally.
so, i think some pressure on the frontpanel must be aggravating a poor solder
joint.
instead of touching all the solder points on the board, are there a few
particularly suspect i might go after first? maybe the pots first? any
suggestions welcome, thanks!
Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel and lay it on us. http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
again.
joint.
