Stuck in a rut (help)
2007-09-19 by Paul Schreiber
Helpful advice from Robert Rich.
> The best use I found for soft sync on the 300 is to
> add the essential non-linear element for chaos
> patches. The "talking chaos" patch, for example, has
> two 300s cross-modulating each other with sign waves,
> both set to approximately the same basic frequency.
> The sync buss is connected, and both are set to soft
> sync. That creates a complex interaction where the
> modules get stuck and unstuck. Wiggling one a tiny bit
> (with a low lagged sample&hold random voltage for
> example) will prevent them from getting locked into a
> pattern.
> As the questioner mentions, The trick of modulating
> VCO pulse width with a high frequency sine for example
> adds a great "fret buzz" sort of timbre to bass
> sounds. For timbral variation within patches, try
> audio-frequency modulating anything with something
> else. Sine waves often make the best sources for audio
> rate modulation, because there's already plenty of
> overtones resulting, so I frequently put a filter into
> full resonance for that purpose.
> If you have two LFOs with FM input, try
> cross-modulating them for complex interactions. If you
> put that output into the VC-in on an oscillator,
> you'll open up a wide range of bleebly sounds, birds,
> wiggly bits, etc.
> Split the output of a filter and process one half with
> other filters and VCAs before putting that signal back
> into an input on the same filter (either audio input
> or the FM input). The feedback loop will affect the
> resonance, and dynamic processing will make the
> interaction very complex.
> For the above idea and for any other patch, add a
> time-domain digital effect - like echo, reverb,
> chorus, flanging, etc - to the inside of a patch. Use
> outboard effects as if they are modules in the system.
> This opens up an entire realm of options for
> feedback-type patches.
> Rethink the standard use for a module. Did you know
> that a lag processor is a low pass filter? An envelope
> generator is a lag processor? An envelope can even be
> a waveshaper for low audio frequencies at its fastest
> settings. Likewise the 320 LFO makes a good audio-rate
> oscillator for bass sounds with very cool waveshaping
> features.
> Two oscillators at their highest frequencies - above
> hearing -  can cross-modulate each other to create
> difference tones you can hear. That's how a Theremin
> works, and radio. You can do it on MOTM oscillators.
> Try modulating a super-sonic VCO with an external
> audio signal. It's very odd. You can do the same with
> resonating filters.
> Speaking of resonating filters, you can "ping" them
> when they are almost ringing by putting a sharp
> envelope blip into their audio input. It makes a very
> ghostly gamelan-like sound.
> The idea behind all of these tips is to break the
> established paradigms and rethink the possible role of
> each module. Don't assume a patch has to go
> VCO-VCF-VCA.
> I hope this helps a bit. - Robert Rich
Re: [motm] Stuck in a rut (help)
2007-09-19 by Jeff Laity
Wow, thank you.
> pattern.
> wiggly bits, etc.
> features.
> resonating filters.
> VCO-VCF-VCA.
NOTICE: This electronic mail message and its contents, including any attachments hereto (collectively, "this e-mail"), is hereby designated as "confidential and proprietary." This e-mail may be viewed and used only by the person to whom it has been sent and his/her employer solely for the express purpose for which it has been disclosed and only in accordance with any confidentiality or non-disclosure (or similar) agreement between TEAC Corporation or its affiliates and said employer, and may not be disclosed to any other person or entity.
2007-09-19 by loopcycle
Now that is an awesome list of experiments to try tonight.
Thanks Robert (and Paul)!
(looking forward to hearing your tune Harry, its still downloading)
Hans
> > pattern.
> > wiggly bits, etc.
> > features.
> > resonating filters.
> > VCO-VCF-VCA.
Got a little couch potato?
Check out fun summer activities for kids.
http://search.yahoo.com/search?fr=oni_on_mail&p=summer+activities+for+kids&cs=bz
2007-09-19 by John Mahoney
At 02:31 PM 9/19/2007, Jeff Laity wrote:
>Wow, thank you.
I'll second that "Wow."
Robert Rich: World's greatest help desk technician! ;-)
john
Checked by AVG Free Edition.
Version: 7.5.487 / Virus Database: 269.13.22/1015 - Release Date: 9/18/2007 11:53 AM
Re: Stuck in a rut (help)
2007-09-19 by Koos Fockens
Thanks Robert and Paul for all these suggestions and tips. I took the liberty to re-post this
on my blog, as I feel a lot of people out there could get something useful out of this. Hope
you guys don't mind :-) I currently have about 50 to 100 visitors per day on my blog.
www.motmsynth.blogspot.com.
Koos
> > pattern.
> > wiggly bits, etc.
> > features.
> > resonating filters.
> > VCO-VCF-VCA.
External feedback; was Re: [motm] Stuck in a rut (help)
2007-09-19 by Richard Brewster
Great!  Thanks.  I get stuck in a rut or two myself.
About this suggestion by Robert:  I use a Lexicon MPX-1 to add effects
through my external mixer send and return.  Great idea to take the MPX-1
output and feed it back into the MOTM.  But it is at line level.  I
don't have an external input module yet.  This looks like another DIY
project.  Blacet has an input module with envelope follower, but I want
a stereo unit.  Ideas?
Richard Brewster
http://www.pugix.com
2007-09-21 by Michael Zacherl (aka TonTaub)
Hi Harry!
Coincidentally it happend two weeks ago that I used that sort of things
in one of our improvisations.
>> pattern.
Many times I do the wiggling myself by playing the synthesizer with
patchcords, knobs etc.
Or I apply a small portion of noise in the control path which also
supports this stuck/unstuck type of pulsation etc.
Since all my patches evolve while performing I just can say that for the
sounds below cross fm with a degree of sync was used.
A lot of experimentation is needed, but it's relatively easy to achieve
a nice result.
Sometimes something I didn't dare to imagine before patching.
Much time goes into fine tuning or preparation before playing.
In many cases before starting the piece I have to do a rough run through
its possibilties to avoid "noise cancelling" ... or getting stuck like
Robert names it.
I took two excerpts of the above mentioned improvisation.
The first one is probably a bit like the talking chaos patch Robert
mentioned above.
The first track is the rough mix from the impro (Eric and me playing)
the second one is just the modular synth (aiff and mp3)
http://blauwurf.info/audio/demos+excerpts/e+m-070912_xcrpts-1b.mp3
http://blauwurf.info/audio/demos+excerpts/e+m-070912_xcrpts-1b.aif  (12MB)
http://blauwurf.info/audio/demos+excerpts/e+m-070912_xcrpts-1s.mp3
http://blauwurf.info/audio/demos+excerpts/e+m-070912_xcrpts-1s.aif   (12MB)
The third track is also the rough mix of a later part of the very same
improvisation, where I played a dirty and pulsing bass sound using the
very same patch  (different settings of course). The fourth one again is
just the analouge track. Beware of the LF!
http://blauwurf.info/audio/demos+excerpts/e+m-070912_xcrpts-2b.mp3
http://blauwurf.info/audio/demos+excerpts/e+m-070912_xcrpts-2b.aif   (34MB)
http://blauwurf.info/audio/demos+excerpts/e+m-070912_xcrpts-2s.mp3
http://blauwurf.info/audio/demos+excerpts/e+m-070912_xcrpts-2s.aif   (34MB)
Btw, there is no abuse of modules ... ok, maybe be playing them with a
hammer ...
No, seriously ... explore the limits, and beyond.
Don't be afraid of for instance higher noise level just because you have
to crank up the gain or such.
Think of functions ... use "flaws" (like unstable voltages ... ok, well
this is a MOTM list  :-p )  as part of the patch etc. (like the drooping
bass above).
       HTH a bit,    Michael.
PS: Always leave "record" on ;-)
nonconform? noiseconform: http://blauwurf.at/
Re: External feedback; was Re: [motm] Stuck in a rut (help)
2007-09-23 by Mark
While I don't own an MPX-1 myself, as far as I can remember, it has
both input and output level knobs, and -10/+4 switches in the back.
So I don't think you would need any any sort of I/O module.  Also,
considering that the MPX-1 can send most of its internal mod sources
as MIDI data, you could use it with a MIDI-->CV converter to create
LFO's, envelope followers, etc.
Anyway, it wouldn't be too difficult to build a 1U triple preamp.
Just put an attenuator before an op-amp, then you would have
adjustable gain from "negative infinity" to whatever you gain set the amp
(eg. 15-20 dB).  You could build it on a MUUB, MOTM breadboard, etc.
You could even use an Oakley multimix panel if you didn't mind the
knobs being labeled wrong.
On 9/19/07, Richard Brewster put forth:
2007-09-23 by djbrow54
I built an interface to my reel-reel for echo and delay using the cgs-
23 board.  Makes for a great preamp.
http://modularsynthesis.com/modules/DJB-012/djb012.htm
I added a switchable gain to my multimix.
http://modularsynthesis.com/oakley/oakley.htm
I added a variable gain to my MOTM-890.
http://modularsynthesis.com/motm/MOTM-890.jpg
http://modularsynthesis.com/motm/MOTM-890_panel.jpg
None of these are stereo but the cgs-23 would probably be the easiest
to do. I like the variable gain the best as it seems to work best
across a number of different external units.  I've found that some of
my rack units can take pretty high levels also.
Dave
the amp
effects
MPX-1
DIY
want
2007-09-24 by Richard Brewster
The MPX-1 has in input level switch to choose between Unbalanced (8 dBu
to -14 dBu) and Balanced (+20dBu to -2dBu).  I am using the inputs
unbalanced at the higher sensitivity, patched from my mixer effects
sends.  I suppose I could switch to the lower sensitivity, but the MOTM
outputs are unbalanced.  Shouldn't matter if the ring lug gets grounded
by a patch cord, right?  The outputs are +18 dBu at max scale.  I'll
just have to try it.  The only thing I did with the MIDI on the MPX-1
was hook it to my keyboard MIDI out.  But I did not try using it as a
controller for the MOTM-650.  I'll try that too.  Thanks for the ideas.
-Richard
2007-09-24 by Mark
On 9/23/07, Richard Brewster put forth:
MOTM is about 13dB.  I'm not sure what those numbers mean, but I'm
guessing the lower number is minimum full scale (below that the S/N
goes out the window), that clipping the analogue input is not much of
an issue, and the input knob is before the AD.
>I am using the inputs unbalanced at the higher sensitivity, patched
>from my mixer effects sends.
Well, most mixers should be able to send a hotter signal.
It shouldn't, although it might reduce the level slightly.  While
Lexicon boxes generally have rather high input impedances (higher
than many other effects), afaik, the "unbalanced" setting has a lower
impedance than the "balanced" setting.
>The outputs are +18 dBu at max scale.  I'll just have to try it.
Unlike most Lexicon boxes, the MPX1 has the convenience of an output knob :)
>The only thing I did with the MIDI on the MPX-1 was hook it to my
>keyboard MIDI out.  But I did not try using it as a controller for
Yes, the MPX1 is rather unique in that regard.  With the tap input
you can use an MOTM-650 to generate synced LFO's.  My PCM-80's can't
do that.  Also, you can use the pedal input as a CV input, so you can
use an MOTM-320 as a mod source.  Although, if it like most Lexicon
boxes, it doesn't like negative voltages, so you need to scale and
offset the 320 output.
RE: External feedback; was Re: [motm] Stuck in a rut (help)
2007-09-25 by Adam Schabtach
Not long ago I built a module for my MOTM system that has four
unbalanced-to-balanced line drivers/converters and two
balanced-to-unbalanced line receivers. The latter act as outputs from the
synthesizer; the former are inputs. This lets me make balanced connections
between the synth and my Apogee converter. I did this mostly because my
studio layout makes it necessary to run longish cables between the synth and
the converter, but I think that it improved the sound quality of the
connection a bit also. Thanks in part to the excellent support for external
hardware in Cubase, this module lets me use my synthesizer as both an
instrument and an insert effect within my DAW.
The module was pretty easy to build. I just used balanced line driver and
receiver chips from THAT Corp. and followed the design suggestions in their
app notes.
--Adam
2007-09-25 by Richard Brewster
Can you post a circuit schematic diagram, Adam?
Richard Brewster
> app notes.
> --Adam
2007-09-26 by Adam Schabtach
Hi Richard,
There's really nothing to post. I copied the circuits directly from the
application notes for the THAT 1646 and THAT 1246 chips. You can find PDFs
of the app notes at THAT's website. Arguably if I did post my circuits it
would be a copyright violation. :-)
The chips are dead-simple to use. The only external components you need are
some caps that are actually optional but improve performance somewhat (if I
remember correctly). You can order the chips from Mouser although they don't
seem to carry the entire THAT line.
--Adam
  _____
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
Richard Brewster
Sent: Tuesday, September 25, 2007 5:29 PM
To: lists@...
Cc: motm@yahoogroups.com
Subject: Re: External feedback; was Re: [motm] Stuck in a rut (help)
Richard Brewster
http://www.pugix. <http://www.pugix.com> com
and
external
their
> app notes.
> --Adam
