Re: Stupid tool question..Intelligent answer
1999-12-18 by Elhardt@xxx.xxx
jlarryh@... writes: >> Even if you can't afford a nice Panavise or something, one of those little $5 jobbies with the alligator clips really work fine too when you REALLY need that 3rd hand.<< I have been using one of those little "dual helping hands" for years, and I don't know what I would do without it in some situations. >>but I check every resistor with my Fluke before soldering them in. Even in good light, the colors are just not all that clear at times. Red and orange are very different on some, yet almost identical on others. Same for brown and violet. Hell, maybe I'm just getting old and blind.<< You are not getting old and blind. The browns, oranges and violets on the blue high quality resistors are almost indistinguishable from each other at times. Why they can't use brighter and more pronounced colors I would like to know. Useful Tip: for those who are using one of those handy $3 lead benders. Have you found yourself bending the leads of those little axial ceramic capacitors and then tried to insert them into the PCB only to find that the holes are spaced narrower than the resistor and diode holes, rendering your lead bender useless, while you cursed the name Paul Schreiber out loud ? Me too ? The solution is to firmly push the capacitor into the round hole in the top of the lead bender, which is used to hang the thing up, and bend the leads around that narrow portion of the lead bender. It will give you a perfect fit. -Elhardt
