Index last updated: 2026-03-31 13:59 UTC
heat sink compound
heat sink compound
2007-08-19 by jneilyahoo@jneil.com
The heat sink compound required for the 420 filter kit, does it matter
if that's silicon or non-silicon?
http://www.hmcelectronics.com/cgi-bin/scripts/product/3480-0008/
http://www.hmcelectronics.com/cgi-bin/scripts/product/8591-0060/
Also, are there any other kits that require it? If not, then I might
just try to buy it in the little 1-gram packets instead:
http://www.mouser.com/search/refine.aspx?Ntt=heat+sink+compound
----------------------- Tear Along Dotted Line -----------------------
John Neilson jneil@...
this message brought to you by 'e-mail' -- safe, clean, Modern!
Re: [motm] heat sink compound
2007-08-20 by Stephen Drake
I use the silicone based kind you can get a Radio Shack for quite a bit less than any of those prices. I don't think it matters if it's silicone or not. And yes, there are lots of other kits that use it - any of the vco's, the 440 and 480, and probably a few others. One tiny tube will probably last you a lifetime, though - a dab'll do ya!
Stephen Drake
sduck409@...
makeme1witheverything@...
2007-08-20 by Paul Schreiber
a) either one will work fine
b) all kits that use a TEMPCO resistor need some.
