MOTM-800 circuit
MOTM-800 circuit
2007-07-25 by David Moylan
I'm looking over the schematic of the MOTM-800 and wonder if a
problematic situation could arise if:
1. Something is jacked into gate defeating the false gate of R15,
 but itself not providing a gate, which would leave the release leg of
the 4066 on.
2. Attack and Release set to 0.
3. A trigger pulse occurs
It seems as though this would set up a fairly low resistance path from
15 volts to ground through the attack and release legs of the 4066.  Is
this not so?  Or is the voltage at C9 and Th provided by the divider
made up of the 2 legs enough to then turn off the attack leg via the 555?
Dave Moylan
Re: MOTM-800 circuit
2007-07-26 by djbrow54
The only path to ground is through U1A.  For this switch to be on, the
control must be high and hence the gate must be low.  If the gate is
low, the 555 is reset, so Q is low and U1C and U1D are off.  The gate
low also disables U1B.  There is no source, just sink, and trigger
won't do anything since the 555 is reset.
Dave
of
> the 4066 on.
from
Is
555?
> Dave Moylan
Re: [motm] Re: MOTM-800 circuit
2007-07-26 by David Moylan
That's what I was missing.  Thanks Dave.
Dave
> Dave
> --- In motm@yahoogroups.com <mailto:motm%40yahoogroups.com>, David
> of
>> the 4066 on.
> from
> Is
> 555?
>> Dave Moylan
