Soldering, etc
Soldering, etc
1999-12-17 by Paul Schreiber
**DISCLAIMER: this is not indended for any 1, 2 or number of people
specifically. **
The following tips are based on 1 year of MOTM soldering/failure issues
a) Parts in backwards
PLEASE resist the urge to power-up a module *before* checking every IC for
being
in backwards. They don't like it. I take great pains in the pcb layout so
that they all point
in the same direction. If you are not sure, just call or email.
Also: twisted pair wiring backwards. Double-check that wires to the jacks
are correct,
not swiched. If it's soldered to the ground plane on the board, it had
better be soldered to the
ground lug of the jack.
b) amount of solder to use
I hope to get some example shots on the web, but before that:
1) generally speaking, you *do not* ever need to apply solder to the top
(component)
side. Except on the top-side ground plane connections, where it is hard to
occur, applying
the solder to the bottom side will flow up and around the top of the lead.
DO NOT add solder
to resistors, diodes, etc from the top side! There should be no "blobs" or
"mounds" of top-side
solder on the leads. There should be just a "wisp" of solder to smoothly
cover the pad surface.
about 1/3rd - 1/4th of the amount the bottom side has.
2) On the bottom: we are NOT going for the "Hershery Kiss" look. Rather, a
moderate-sized, evenly
distributed and flowing around the lead. The "BB pellet" look is bad, too!
c) you MUST wash off the organic flux!
I have seen some ...errr...."interesting" things happen when the organic
flux is left on (no, it
doesn't eat a gaping hole). Rather, you get large (I mean LARGE) DC offset
voltages. One board
had 2 volts of DC offset on the FM 1 jack!! Turns out, the op amp had the
organic flux on every
pin and this caused leakage currents to flow into a 1M resistor (that's 2ua!
Zowie!). BE SURE
the board is washed.
Now, what happens if *all* components are in, and you have to replace
something. Use the no-clean.
d) Do not use the lead clipper as a lawnmower
I have seen more than one instance where the leads have been trimmed almost
flush with the pcb.
THIS IS NOT GOOD, What you want is to NOT CUT INTO THE SOLDER, just trim the
lead.
DO NOT trim IC pin leads: they are OK.
Conversely, I have seen several "forgotten" leads left untrimmed, causing
intermittant (sp?) shorts.
e) it's *OK* to trim the wires in the kit to suit
I use "generic" wire lengths to cover most cases in the kits. But sometimes
the wire is too long. So,
if you feel that taking a 1/2" off would be better, OK!!
Again, I'm not picking on anybody. Just trying to address some assembly
issues. Nothing beats a good visual
inspection before power-up!
Re: Soldering, etc
1999-12-17 by Cary Roberts
I have a DIY modular someone else built.  If you need examples of what
NOT to do I can take some pictures.
-Cary
Re: Soldering, etc
1999-12-17 by hodad1@xxxxxxxxxx.xxx
I think that doing a somewhat more extensive soldering guide would be a good
idea.  I'm sure I'm not the only person whose first diy experience was an
MOTM kit, & I know I'm not the only one out there with a pretty limited
understanding of electronics.
Though I'm getting better as a solder jockey (I think), there are some
things I still don't do all that
well (eg solder wires to 1/4" jacks).  & yes, I've soldered an IC in
backwards.  Damn, did I feel stupid.
& I'm sure a handy tip here or there could help to improve my soldering
technique a good deal.
tomr
Re: Soldering, etc
1999-12-17 by Christopher Jeris
> flush with the pcb.
> lead.
I do this accidentally sometimes, then I usually remelt the blob of
solder.  Should I give up and replace the offending component instead?
peace,
Chris
Re: Soldering, etc
1999-12-17 by william Hanson
yeah- I would get a new part - ....start
over - if Ya clip em' sometimes the
solder point is half cold and half
hot (connection wise) and clipping it
too close just makes the cold part of
the joint worse.
happy synth tweakin' .,,Bill
Do You Yahoo!?
Thousands of Stores.  Millions of Products.  All in one place.
Yahoo! Shopping: http://shopping.yahoo.com
Re: Soldering, etc
If it's not severe, a remelt shold work *as long as* there is still some of
the lead "sticking out"
the hole.
To: MOTM listserv <motm@onelist.com>
Sent: Friday, December 17, 1999 11:46 AM
Subject: Re: [motm] Soldering, etc
> From: Christopher Jeris <cjeris@...>
almost
> > flush with the pcb.
> > lead.
> peace,
> Chris
Re: Soldering, etc
Let's see 'em!
To: motm <motm@onelist.com>
Sent: Friday, December 17, 1999 10:46 AM
> From: Cary Roberts <Cary.Roberts@...>
> -Cary
Re: Soldering, etc
1999-12-17 by The Old Crow
> flush with the pcb.
> lead.
  This used to be a MAJOR problem at my old workplace.  It took me a long
time to get this one board assembly person to not clip the connection off
flush with the board.  (It was *bad*.  This person would often shear
through the traces and/or cleave the pads away from the board with the
edges of the cutters).
  Another problem I had to constantly fight over was the solderers'
tendency to place all the components of a type (resistors, for example)
into the holes, cinch the leads at almost 90deg, solder, then *cut the
lead off with the cutters vertical wrt to the board*.  I would frequently
find the trace coming from a pad cut through as they clipped the wire with
the tips of the cutters touching the board.  Eventually, I cured them of
this too.
  --Crow
