MOTM-compatible Gate Delay now available
2007-05-26 by Suit & Tie Guy
over at
http://stgsoundlabs.com/products/yves_usson_gate_delay_motm.htm
it's in the MOTM physical format, but with a different style of panel
art. it also has power connections for both MOTM and Synthesizers.com
power systems. all front panel connections are made with industry-
standard MTA100 connectors, so in the event of potentiometer, switch,
jack, or PCB failure no soldering is necessary for field replacement
presuming appropriate assemblies are on hand.
thanks much,
Suit & Tie Guy
suitandtieguy.com
