Interested in Tau Pipe Phaser / Flanger boards ?
2007-05-25 by JH.
Hi, many of you may already know about this strange effect device, which sounds more like a flanger (some say, like a thru-zero flanger!), but actually is a phaser with 20 (twenty!) all pass filter stages. If you haven't heard it yet, go to http://www.keyboardmuseum.org/soundsheet/soundsheet.html , scroll down to "The Pipe Phase Demo Record" and listen to the demo. The service manual is located here: http://www.musicsynthesizer.com/Diode%20Phaser/Diode%20Phaser.html I think it's quite impressive and extreme sounding, and it's closely related to the ARP Quadra Phaser which I've cloned some years ago: http://home.debitel.net/user/jhaible/additional_schemos.html And, looking for a project to further develop my pcb layout skills with RIMU before I start that big Vocoder, I thought the Tau Pipe would be a good choice. I've redesigned the original circuit, such that there are no more exotic components (no more obsolete dual FET), and all the circuitry that originally was potted in the infamous PD-10 modules, is part of the main circuit board in my version. I plan to make the layout such that you can *either* (1) use cheap CA3086 transistor arrays *or* (2) - for an ultra low noise version - SSM2210, MAT-02, LM394 (expensive! 20 pairs needed!) *or* (3) use hand matched discrete transitors (unexpensive, but requires a lot of work.) Also on the board will be the complete power supply (except the mains transformer), and you can either connect a small transformer with 2 * 18V AC secondary voltage, *or* connect a single 18V AC source such as a Wall Wart. All pots and jacks and LEDs will be connected externally with flexible wires to allow some flexibility on the form factor (19" rack enclosure, or tabletop box, or even an oversized stomp box). The PCB has a rather small size for what it contains (90mm * 160mm), but it's probably too big to fit behind MOTM or other typical modular front panels. I'm currently in the process of having a first prototype made. I may also create a Schaeffer front panel later (haven't decided on 19" 1U or Tabletop version yet.) So, is there any interest for others to buy these PCBs, when / if the thing works as intended? In the past, I've mainly built on veroboard and had to turn down requests for pcb boards, or even for readily assembled modules. Now, that I've bought a layout software, the situation has slightly changed for the better :) So, if you're interested in getting a board, let me know. Right now, I have no idea what it will cost - keep in mind the whole project will not be cheap, with all these transistor pairs! I won't offer complete kits. If there's enough demand, I'll sell the naked PCB boards, and publish the building information on my web site. Let me know if you're interested, to find out if it's worth the effort. JH.
