New noise reduction board for Frequency Shifter
2007-03-24 by JH.
I had built a compander system around the Philips NE572 chips, but whatever I tried in terms of operating level and time constants, that thing did sound horrible. (That's the reason I hadn't published that part in the first place.) Now I've replaced it with an OTA-based compander, similar to the one I had used in the FS-1 Frequency Shifter. Which, in turn, has been inspired by the compander inside the Roland Vocoder Plus. It has an almost infinite compression ratio (more ALC that compressor), and it's feed-forward sidechain allows 2-pole filtering after the level detector for a very smooth operation. Frequency Shifters are quite demanding for compressors, as the output signal can be so much different from the input signal, and there is none of the cancellation of distortion products many traditional companding systems rely on. Here, in the Matrix FX, the expander's control current is directly copied from the compressor's - and not derived from the expander's input signal. The only drawback of this method is that the CV is "a little too fast" compared with the signal, which is slighly delayed in the dome filter. I practise, this wasn't a problem, however. See http://jhaible.heim.at/matrix_fx/jh_matrix_fx.html - the new stuff is highlighted in Red. JH.
