New audio clip of Matrix FX frequency shifting
2007-03-24 by JH.
Six minutes (5.7 MByte of mp3) of playing around with the Matrix FX and Farfisa VIP500 organ. The Farfisa's upper manual sound goes thru the phaser (set to Compact A mode, and modulated by the envelope follower with a large amount of "Bounce".), and then into two frequeny shifters (downshift on left stereo channel, upshift on right stereo channel). The Farfisa's lower manual sound goes thru the diode ladder filter (slightly modulated by a self-cycling Trapezoid generator), and then into the phaser (see above). Also, the lower manual feeds the BBD delay, which is mixed to the center of the stereo output after the frequency shifter. The whole sound is treated with reverb (Quantec, with a large cathedral setting). I've deliberately used a rather thin organ, and not a synthesizer, as input for the Matrix FX, to demonstrate its sound modifying capabilities. http://jhaible.heim.at/matrix_fx/jh_matrix_fx_fshift.mp3 JH.
