new 'scope owner...
new 'scope owner...
2007-03-24 by Phil Peery
Hi everyone,
I finally got my hands on my first scope, and Owon color digital
storage scope - dual channel, 25M bandwidth, sampling rate of
100MS/s, and 6k points of record length per channel.  I'm like a kid
in a candy store with this!
So my question to the group is, is there anyone with lots of
experience with using these cool devices that would be interested in
guiding me a bit as I learn to use this thing?  The concentration
would be how to use a scope to monitor and test MOTM modules.  My
intention is to write a doc, to be posted here, for all of us scope
newbies to learn from.  I would think that any assistance giving
could be done primarily be email.  If anyone is interested, please
contact me off-list.
I'm off to play with my new toy!  Gonna hook it to my MOTM-390 first!
Best Rgards,
Phil
Re: [motm] new 'scope owner...
2007-03-24 by jneilyahoo@jneil.com
> Hi everyone,
> I finally got my hands on my first scope, and Owon color digital=20
> storage scope - dual channel, 25M bandwidth, sampling rate of=20
> 100MS/s, and 6k points of record length per channel.  I'm like a kid=20
> in a candy store with this!=20=20
> So my question to the group is, is there anyone with lots of=20
> experience with using these cool devices that would be interested in=20
> guiding me a bit as I learn to use this thing?  The concentration=20
> would be how to use a scope to monitor and test MOTM modules.  My=20
> intention is to write a doc, to be posted here, for all of us scope=20
> newbies to learn from.  I would think that any assistance giving=20
> could be done primarily be email.  If anyone is interested, please=20
> Best Rgards,
> Phil
I'm in the same boat, having just gotten a used Tektronix for the same
reasons just last month.
I spent an evening with it and got it to display the waveform of an
electronic tambura box (as fun to watch as it was to listen to), but it
was all trial-and-error.  Outside of a few obvious controls I found a lot
of the options mystifying, and that was before a skim through the manual
left me with as many questions as answers...
For example, is there a reference standard for calibrating these things?
Or should I just send a full-strength signal out of the modular and tweak
things until the waveform fills the screen?  Right now I'm not seeing
enough amplitude, and I'd rather keep an amplifier out of the input path
if I can.
Thanks for getting this ball rolling!
JN
----------------------- Tear Along Dotted Line -----------------------
John Neilson                                           jneil@...
    this message brought to you by 'e-mail' -- safe, clean, Modern!
2007-03-24 by Ben Stuyts
> things?
> tweak
> path
> if I can.
I'll give this a try...
I usually keep the vertical scale at some calibrated value. A lot of
scopes have a separate gain setting for each channel, separate from
the V/div setting. I keep it at the default ('calibrated') setting,
so that I can read off the waveform's amplitude from the screen.
Keep in mind that some probes have a 10:1 attenuation built in. If
your scope has a 5 mV/div max sensitivity, this will become 50 mV/
div. Some scopes might show some noise (up to 0.2 or 0.4 div on your
screen) on their most sensitive setting, so it is best to avoid this.
This makes it difficult to focus on low-level signals. Use a 1:1
probe, or a switchable 10:1 / 1:1. However, you will need the 10:1
probe if you need to measure on a high-impedance circuit. For the
analog inputs and outputs a 1:1 probe will do just fine, and you can
set your scope to something like 1 V/Div to start with.
It is kind of odd that you have trouble filling the scope's screen
(if I understand you correctly) with the output of an MOTM module. It
really shouldn't be a problem. Have you checked your probes?
With kind regards,
Ben
Re: new 'scope owner...
2007-03-24 by djbrow54
Go to www.tektronix.com and get their primer
XYZs of Oscilloscopes
It takes a bit to find it so here is a shortcut.
http://www.tek.com/Measurement/App_Notes/XYZs/03W_8605_2.pdf
Dave
--- In motm@yahoogroups.com, "Phil Peery" <ppeery@...> wrote:
> Hi everyone,
first!
> Best Rgards,
> Phil
2007-03-24 by Richard Brewster
A high quality probe is essential, and isn't necessarily included when
you buy a 'scope.  You want a 10x probe if you're going to look at the
internals of circuits, so as to minimize the loading effect of the
probe, which becomes a part of the circuit and changes it to some
degree.  If you've got two channels, you should use them, so you'll need
two probes.  The purpose of looking at two signals is to view their
relationship, triggering on one of them and seeing what the other is
doing at the same points in time.
Become familiar with the triggering options and controls.  You normally
want to use internal triggering from one of the two inputs.
When looking at a signal, switch around to a number of different
frequency ranges, and tune the brightness down to get a clear, sharp
image.  One of the most useful things you can discover with a scope
looking at audio is ultrasonic high frequency oscillations (known as
parasitics) riding on top of the main waveform.  You don't want these!
They cause distortions of the bad kind (as opposed to the good sorts
that we all love).  If you find parasitics and make changes to fix them
(usually by adding a small capacitor in the feedback loop of an op amp),
the scope tells you if your fix worked.  The scope opens up a world of
visualization of what's happening.
I give another example.  I recently built a pair of CGS Tube VCA
modules.  Looking at their output on my Veeblefetzer LED displays showed
that the outputs were skewed into the negative voltage region.  I
thought something was wrong, because the output is AC coupled.  I
expected the signal to be centered.  A quick look with the scope showed
what was going on.  The wave shape was a non-symmetrical pulse wave with
the energy concentrated in the negative region.  Nothing was wrong.  The
Veeblefetzers are great, but cannot show the detail a scope can.
-Richard Brewster
http://www.pugix.com
>> things?
>> tweak
>> path
>> if I can.
> With kind regards,
> Ben
Re: [motm] Re: new 'scope owner...
> Dave
Oh, yeah, I was hoping something like this was out there somewhere!
I'll try to go through this before asking too many idiotic questions.*
Thanks!
*I'm not an electrical engineer, I just play an instrument that makes me
look like one.
2007-03-24 by wjhall11
Will and I are soon to be in the same boat - getting our scope soon.
Thanks so much for this thread - we'll be listening attentively... if
you guys decide to take it offline, please include us, OK?  Thanks.
Bill and Will
> > Dave
> Thanks!
> look like one.
Hi Rob,
On 24 Mar 2007, at 11:03, rob wrote:
Is there a way of displaying an ADSR output on a basic analog scope? (no storage facilities)
So I can measure time periods and check envelope linearality/expo..
That is kind of tricky because of the slow nature of the signal. First, you must have a repeating trigger on the ADSR, so hook it up to an LFO or something like that, maybe at 0.2 Hz or so. You'd probably want to set your time base to ca. 0.5 or 1 s/Div so you can view the whole envelope from start to end. Next, as Richard mentioned in his excellent post, triggering is crucial. Make sure the scope is not set to some sort of auto-trigger mode, but triggers exactly once on each rising edge of the ADSR. A scope usually has a separate trigger input. You might get a more stable picture if you hook up the trigger of the scope to the gate or trigger input of your ADSR.
Some scopes have some persistancy in their screen. If you turn down the surrounding lights, you might be able to see a ghost of where the waveform was.
Hint: make your own storage scope with your digital camera set to 5 or 10 s exposure time...
With kind regards,
Ben
2007-03-24 by Seth Elgart
>look like one.
That's hilarious. Can we make t-shirts or something?
          Seth
Proud owner of a roughly-paperback-sized LCD scope, but still looking
to pick up a Tektronix on eBay.
2007-03-24 by Doug Wellington
Don't know what you're after, but check this guy out:
http://www.users.qwest.net/~jbau/tstequip.htm
For example, it looks like he has a Tek 7623A 100 MHz storage scope for $165.
Doug
http://www.analognotes.com
