infinite phaser demo
2007-03-10 by JH.
Here's another mp3 clip from playing the Matrix FX.
http://jhaible.heim.at/matrix_fx/matrix_fx_infinitephaser.mp3
 "infinite phaser"
A short clip (427 kByte of mp3) demonstrating the use of a Frequency Shifter
as an "infinitely" rising phaser. White noise is fed into the SSB Modulator
1 (= Frequency Shifter), with the shift amount (= OSC 1 frequency) way into
the sub-audio (LFO) range. Frequency shifter output is mixed with the direct
signal. Frequency shifter output is also fed ito the phaser (12 pole Moog
mode, only the wet signal used, i.e. acting as an all pass filter!), and
then fed back to the Frequency shifter input. A certain anount of Loop gain
added with the Inv/Amp to get enough resonance. (Can't use the phaser's own
resonance here!).
http://jhaible.heim.at/matrix_fx/jh_matrix_fx.html
JH.
