MOTM-800 PCB.
MOTM-800 PCB.
2007-02-02 by brownchonald
Are the parts for the MOTM800 EG hard to find?
I'm thinking this will be a great project for the EGs I need.
I just want to make sure, before I purchase some PCBs, that I'll be
able to build them.
Cole
Re: [motm] MOTM-800 PCB.
2007-02-02 by Paul Schreiber
Ok the *pots* are hard to find. Everything else on the pc board is <$5 at
www.mouser.com
To: <motm@yahoogroups.com>
Sent: Friday, February 02, 2007 4:30 PM
Subject: [motm] MOTM-800 PCB.
> able to build them.
> Cole
2007-02-03 by Richard Brewster
Paul sells the kit of 4 pots for $39.  Add the panel and the MOTM-800 PC
board for $19 each and you have a basic MOTM-800 kit for $77.  The
remaining parts are probably under $25 from Mouser. Not bad.  I like
this trend!  Much like putting together a module from Oakley, but with a
reasonably priced, perfectly matched panel.
Richard Brewster
http://www.pugix.com
> www.mouser.com
> Paul S.
> From: "brownchonald" <chonald@...>
>> able to build them.
>> Cole
>> Yahoo! Groups Links
2007-02-03 by Ben Stuyts
> MOTM-800 PC
> with a
Don't forget to get the bracket to mount the pc board to the front
panel. It's the BR-15 bracket, which is $6 at Paul's webshop.
I am working on an MOTM-800 right now, and I agree, it is an easy
board to build with easily available components.
Ben
