Index last updated: 2026-04-03 18:09 UTC
A few things about the orders about to ship
2006-12-07 by Paul Schreiber
1) We are out of MOTM-960 boards. I will order the parts for 50 more, if you do
not receive a MOTM-960 by the 20th, they will ship after Christmas break (around
Jan 8th or so).
b) Same is true for the MOTM-910 mult. I am switching over to a pcb design
versus hand-wiring. I have to tweak the footprint of the new vertical jack, and
have more pc boards made.
c) remember, if you live in the EU, I *cannot ship solder*. You will have to
provide your own. Check the archives for vendors and part numbers.
d) I may have miscounted the MOTM-890 available kits. If this is so, I will
refund your money via a credit cart transaction or PayPal payment. I may have
additional blank boards, but no panels.
e) Indiana has decided to kit up all 375 modules and then ship en mass. The
shipping begins tomorrow :) I am going to try to add PHP code (God help me) to
the SQL Server so that I can issue a 'partial shipment' status email (right now,
I have a 'shipping now' status but that is hard to apply to a partial shipment).
I may not be able to figure it out, so if you get a 'shipping now' email, do NOT
assume it is for *all* that you have ordered. I just means  I suck at PHP.
Re: [motm] A few things about the orders about to ship
2006-12-07 by Ben Stuyts
(Apologies if you see this twice. I sent it from a wrong address
earlier and it didn't turn up I think.)
> will have to
No problem, I still have rolls of the good old leaded (60/40) rosin
core stuff. Just to make sure: the parts and boards are not lead-free
and need to be soldered using lead-containing solder, right?
What is the reason that you use two different kinds of solder
(organic and no-clean)? I could not find that in the archives.
(Actually lead-containing parts/solder/etc. are still available here,
as long as you basically do not manufacture anything new with it.
It's perfectly legal for use in service and spare-parts for example.
Also, certain areas of industrie are excluded for at least until 2008.)
With kind regards,
Ben
2006-12-08 by Richard Brewster
The organic solder has water-washable flux.  It is used for soldering
most of the parts onto a PC board, which is then immediately washed in
warm water to remove virtually all of the flux residue, leaving the
board very clean.  Any parts that cannot be water-washed are soldered on
after that with normal no-clean solder.  It is very important to wash
off all of the organic flux, because it is corrosive if left.  The
no-clean solder leaves some flux residue, but that is not as corrosive
as the organic flux.
Richard Brewster
http://www.pugix.com
2006-12-08 by Cecil Grey
What parts are not water-washable, exactly?
I can guess the obvious: potentiometers, trimmers, ICs...
But what about caps and transistors? Are diodes ok?
(I haven't assembled an MOTM kit yet, so apologies if this is covered in the instructions)
Cecil
Cecil
