My website updated
My website updated
2006-12-03 by Richard Brewster
New pictures show the final cabinet atop the others.  The eight 2U blank
panels are all the space that's left.  Go here and scroll to the middle
of the page:
http://www.pugix.com/overview.htm
New recordings of a big drone patch I've been playing around with.  At
the top is another picture of the big drone patch, in which the new
cabinet shows a little.  Scroll to the bottom for the MP3's.
http://www.pugix.com/music-samples.htm
I have moved modules around quite a bit.  (Now why did I make my website
have pages corresponding to the cabinets?!)  I hope to find time to take
more, and better, pictures of each module.
Richard Brewster
Re: [motm] My website updated
2006-12-03 by Scott Juskiw
Great pictures and sounds, that's a nice synth you've got there.
But I'm wondering how you reach the top cabinet controls, are you 7
foot tall? A long time ago I was discussing with Larry the practical
size of a synth. Four rows seemed to be about the upper limit if you
have it placed on a table top with keyboard in front. In my case, I
expanded downwards with no keyboard in front so that I can have 6
rows within reach. How are you managing with 5 rows on a table top?
2006-12-04 by timothy cooper
Definately an amazing rig se\ufffdor!  Lots of "synth porn"
to peruse for sure!  Question: Do you possibly have
any sound samples, or know of any samples online of
those Bi-N-Tic filters, and also the Wave Multiplier?
Those are kinda on the top of my wishlist right now
for when I get my Christmas bonus here at work:)
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail beta.
http://new.mail.yahoo.com
2006-12-04 by Richard Brewster
Thanks, Scott.  I work standing up.  I'm a little under six feet tall
and I have long arms.  I can reach the highest pots in the top cabinet
without stretching.  I do not plan to put modules with jacks high up on
the panel into the top cabinet!  Note that the keyboard sits at the same
level as the bottom cabinet.  If I raised everything up with a hutch
like the dot com 'keyboard garage':
http://www.synthesizers.com/cabinets.html#qcskg
I would have a problem reaching the top.  But I don't plan on doing that.
Richard Brewster
If you are not already on the CGS email list, you can sign up here.
http://launch.groups.yahoo.com/group/cgs_synth/
There are some Bi-N-Tic filter examples in the files section.  Both it
and the Wave Multiplier are wonderful modulators.  One of the voices in
the Big Drone patch uses the Wave Multiplier.  It makes fantastic
harmonics.  Both of these are worth doing if you DIY.  I would like to
provide more sound samples for the unusual modules in my synthesizer,
and I hope to get around to it.
-Richard Brewster
My website updated
2007-03-04 by Richard Brewster
I got around to updating my website today.  I added the long promised
Wogglebug project page with full schematics and pictures, plus the three
latest modules:  Blacet StonZ Phaser, Oakley Superladder VCF, and CGS
Tube VCA / Timbre Modulator.  And a picture of the back of my CGS
Digital module, which has 8 circuit boards.  I took a new photo of the
MOTM-650, too.
No, I'm not done, yet!  I am waiting for more MOTM to be announced.
Be sure to refresh your browser cache.
-Richard Brewster
2007-03-05 by Mark
I'm very curious about the pentode VCA.  It looks like a very promising
module for a number of reasons.
http://www.cgs.synth.net/modules/cgs27_tube.html
The parts are inexpensive and the design seems relatively simple.  In
fact, I'm thinking it would take less time and money to build than an
OTA-based design.  Perhaps more importantly, it only uses +15V for
the plate voltage, so it does not require a separate power supply and
it is relatively safe for DIY.
The use of +15 plate voltages with pentodes also opens up the
possibility of other voltage-controlled modules using tubes such as
filters and waveshapers.
How well does it work??  Do you have any examples how it sounds?
While cut-off tubes are used in compressors, I was under the
impression they didn't work well as gates. Did you have to bias the
control voltage??  Did you connect the suppression grid to the
cathode??
Did you use a PCB from CGS??  There appears to be two, a CSG65 and a
CSG27.   What did you use to supply the heater voltage??  I'm
thinking a dual module using 6064 tubes would draw around 600mA,
which would be about 75% of an MOTM-900. Then there is the other CGS
tube VCA, that uses a tube that only draws 13mA:
http://www.cgs.synth.net/modules/cgs65_vca.html
Unfortunately, I am totally unfamiliar with the 1J24B /1J24B  and I
cannot seem to find anything about it online written in English.
I'm not familiar with directly-heated cathodes, so I'm a bit confused
what pin 3 does, and the heater circuit shown in the CGS65 schematic.
It also looks like the suppression grid is connected to the negative
rail??
Thanks for the update.  Your consideration is appreciated.
On 3/4/07, Richard Brewster put forth:
>MOTM-650, too.
>-Richard Brewster
2007-03-06 by Richard Brewster
I built two of the CGS65 VCA / Timbre Modulator. To quote Ken Stone:
The tube chosen is the Russian sub-miniature 1J24B (1SH24B, 1\u041624\u0411). It
operates on low voltage, and uses a mere 13ma at 1.2 volts for its
heater. In other words, the heater uses less power than the average LED.
For more information, post to the cgs_synth Yahoo group.
I plan soon to create sound samples from all of the more esoteric
modules in my synth, including this VCA. I classify it as a Timbre
Modulator. While it is also a VCA, it's tweaked towards distortion for
input levels above about 2V p-p. As the level increases, a triangle wave
input morphs into a type of pulse wave with quite pleasing harmonics.
Using an envelope to make this dynamic produces musical results.
-Richard Brewster
> cathode??
> rail??
>> MOTM-650, too.
>> -Richard Brewster
2007-03-06 by Mark
On 3/5/07, Richard Brewster put forth:
OK :)
While that's a good idea, I'm not on that list.  I asked you about it
here because you actually built one, and DIY modules in MOTM format
seem to be one of the subjects of this list.
I would be interested in hearing that.
>I classify it as a Timbre Modulator. While it is also a VCA, it's
>tweaked towards distortion for input levels above about 2V p-p. As
>the level increases, a triangle wave input morphs into a type of
>pulse wave with quite pleasing harmonics. Using an envelope to make
That makes sense, although I am also interested in how well it works
as a VCA.  Which is perhaps why I asked a bunch of technical questions about
bias voltages and suppression grids :)
Thanks again for your input.
