Rack rail spacing
2006-12-03 by wjhall11
2006-12-03 by > angelzero <
> All - new to MOTM, I'm designing a case for the____________________________________________________________________________________
> modules I'll be
> building. I'll build the case out of wood - and I'm
> planning to screw
> the moduldes directly into wood rails - top and
> bottom. In your
> experience, what should the optimal spacing between
> the rails be?
> Based on the face plates of the module kits I've
> recieved, I'm
> thinking 7-7/8" should do the trick. Sound right?
> Thanks much. Bill
2006-12-03 by Dave Bradley
On 12/3/06, wjhall11 <wjhall@...> wrote:All - new to MOTM, I'm designing a case for the modules I'll be
building. I'll build the case out of wood - and I'm planning to screw
the moduldes directly into wood rails - top and bottom. In your
experience, what should the optimal spacing between the rails be?
Based on the face plates of the module kits I've recieved, I'm
thinking 7-7/8" should do the trick. Sound right? Thanks much. Bill
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/motm/
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/motm/join
(Yahoo! ID required)
mailto: motm-digest@yahoogroups.com
mailto:motm-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
motm-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
Dave Bradley
2006-12-03 by djbrow54
>screw
> the moduldes directly into wood rails - top and bottom. In yourBill
--- In motm@yahoogroups.com, "djbrow54" <davebr@...> wrote:
> I made my openings 1/16" wider and taller than the panels.
> My height is 8 13/16" with 1/2" top and bottom rails that I faced with
> Stooge metal rails. I inset the face of the panel 1/8" from the
> outside edge. The external depth is 10" which has been plenty. I
> have a 1/4" rear panel and my front panels are inset so the internal
> depth is 9 1/2".
> I was a bit concerned with having the cabinets be exactly square so I
> allowed a bit more side to side spacing on one cabinet I built. I
> allowed and extra 1/8" which does leave visible gaps on each end. I
> used a piece of adhesive backed 1/4" open cell foam and lined each
> side of the cabinet just at the rear edge of the panel. That worked
> great to hide and seal the edges.
> I've got a few photos on
> http://modularsynthesis.com/cabinet/cabinet.htm
> that show some of the construction details.
> I really like the Stooge rails and would rather have metal than wood.
> One alternativie since the Stooge rails aren't available would be to
> use standard rack rails like
> http://www.musiciansfriend.com/product/Middle-Atlantic-18Space-Rack-
> Rails?sku=549508
> I have built a couple of racks using standard rack rails and would
> think they would work just fine. The ones I used were 5/8" wide so
> you would have to increase the internal opening to 9" which would
> leave a 1/8" gap across the top and bottom of the module, but with a
> nice black anodized rail behind it to hide it. Or, if you are fancy
> with a table saw, dado in a 1/8" deep grove to set the rack rail into.
> One mistake I made with my cabinets is that all the weight is in the
> front. I put mine on center pivots and really had to use non-slip
> washers to lock the cabinets in place.
> Dave
> screw
> Bill
> Thanks for all the help, guys. I'll make thehttp://www.musiciansfriend.com/product/Middle-Atlantic-18Space-Rack-
> spacing 7-3/4".
> I've created some schematic drawing of the face
> plates of MOTM
> modules. I'm using these to plan my synth - but in
> the long run to
> create patch sheets to record my patches (borrowing
> an idea from a
> friend who had such sheets for the Synthi-A he sold
> me of yore). It
> occurred to me that they might come in handy for
> others to use. I'm
> loading them to a website I have. I'll put out the
> URL when I'm
> finished loading them nicely.
> Thanks for the tip about the weight, Dave. I'm
> going to put handles
> on the side of the cabinet to make carrying it
> easier and I had
> thought I'd better put them to the front. Per your
> warning, I
> certainly will.
> Thanks again. Bill
> panels.
> 1/8" from the
> been plenty. I
> > depth is 9 1/2".
> exactly square so I
> cabinet I built. I
> gaps on each end. I
> foam and lined each
> panel. That worked
> > Rails?sku=549508____________________________________________________________________________________
> rails and would
> were 5/8" wide so
> 9" which would
> module, but with a
> the rack rail into.
> to use non-slip
> > Dave
> modules I'll be
> I'm planning to
> > screw
> bottom. In your
> recieved, I'm
> right? Thanks much.
> > Bill
2006-12-03 by Jay
