MOTM <-> guitar stomp-box pedals
2006-10-13 by Eric Frampton
howdy friends - Are there any modules or kits, in addition to the Ken Stone CGS one, that'll convert MOTM audio levels down to guitar pedal levels (and impedances) then back up again? Not that there's anything wrong with the CGS kit, I'm just curious what else is out there. e
2006-10-13 by xamboldt
Cyndustries Anything Module: http://www.cyndustries.com/modules_anything.cfm -Chris
On Oct 13, 2006, at 12:57 PM, Eric Frampton wrote: > howdy friends - > > Are there any modules or kits, in addition to the Ken Stone CGS one, > that'll convert MOTM audio levels down to guitar pedal levels (and > impedances) then back up again? Not that there's anything wrong with > the CGS kit, I'm just curious what else is out there. > > e > > >
2006-10-13 by Mike Marsh
I use an Oakley EFG Deluxe to get the guitar in, but don't usually need to come out except the the console, and that's all good. It's not one of the boards he is re-issuing, as I understand it, but Blacet has one and so does Synth.com... Mike --- In motm@yahoogroups.com, Eric Frampton <eric@...> wrote:
2006-10-13 by John Mahoney
At 12:57 PM 10/13/2006, Eric Frampton wrote: >howdy friends - > >Are there any modules or kits, in addition to the Ken Stone CGS one, >that'll convert MOTM audio levels down to guitar pedal levels (and >impedances) then back up again? Not that there's anything wrong with >the CGS kit, I'm just curious what else is out there. > >e Cynthia's Anything Module has a couple of sends and returns, one mono and one stereo.. The dotcom Signal Processor (send) and Instrument Interface (return) modules should also work. A Reamp box (www.reamp.com) should ** handle the outbound signal nicely but you still need to amplifier the return signal. ** I read on one of these synth lists that the "pro" +4 dB (dBu or dBv? I can never remember) signal is the same as +/- 5V. True? -- john
2006-10-13 by Jay
John Mahoney wrote: > Cynthia's Anything Module has a couple of sends and returns, one mono > and one stereo.. > > The dotcom Signal Processor (send) and Instrument Interface (return) > modules should also work. > > A Reamp box (www.reamp.com) should ** handle the outbound signal > nicely but you still need to amplifier the return signal. > > ** I read on one of these synth lists that the "pro" +4 dB (dBu or > dBv? I can never remember) signal is the same as +/- 5V. True? > -- > john Don't forget the new Cwejman module: http://www.analoguehaven.com/cwejman/ai2/ Although, that wouldn't be fun to try and convert...
>howdy friends -
By the way, it's quite simple to attenuate the output level with a
passive volume control. I had a surprisingly hard time finding a
simple illustration of this on the web about a week ago, so I made this page:
http://www.bitshifted.com/circuits/volume_control.html
This will do nothing to deal with impedance, of which Reamp makes a
particularly large issue. But for the price of a pot and some jacks,
it's worth a try. Then all you need to do is amplify the return
signal. As they say, YMMV.
Comments and corrections if needed, please.
john2006-10-22 by Mark
>Are there any modules or kits, in addition to the Ken Stone CGS one, >that'll convert MOTM audio levels down to guitar pedal levels (and >impedances) then back up again? Not that there's anything wrong with >the CGS kit, I'm just curious what else is out there. Short Answer: Use a cable with a 1/4" jack on each end. Plug one end into the MOTM and the other end into the pedal. Long answer: Over the years, I've seen a number of posts asking how can I connect MOTM to some other thing. So I'm going to explain how. The most important thing to consider when using line-level signals such as MOTM is that the output impedance must be lower than the input impedance. You do not "match" impedances when using a modular synth. Why is this so important?? The output needs enough current to "drive" the input at the output voltage. In order to do this, the output impedance must be higher than the input impedance. The impedances do not have to be close to each other. Nor do they need to differ by a massive amount. Fortunately, with the exception of microphone pre-amps, it's extremely rare to find two things that you would want to connect to each other, where the output impedance of is higher than input impedance. Mic pre's can have a very low input impedance. So if for some reason you wanted to connect something other than a microphone to the input of a mic pre it could result in serious damage. (Why do many mic pre's have such low input impedances?? It has to do running a low voltage signal over a balanced connection. Lowering the impedance increases CMRR, and reduces high frequency loss and slew limiting from long cable runs. If the output impedance is the same as the input impedance there is 6dB of attenuation. So the input impedance should be at least five times the output impedance, but not so high that the microphone isn't "working". Since a balanced microphone can have an output impedance anywhere from 20 to 600 Ohms, a mic pre can have input impedance as low as 100 Ohms, although higher values are much more common.) In practice, I have connected headphone outputs with an output impedance of a few ohms or less to instrument inputs with an input impedance of 1M (~50,000 times greater), and I have connected gear with an output impedance of 2K and an input impedance of 20K (only ten times as much), without problems. How is this possible?? Just like MOTM modules, almost all modern effect pedals, rack effects, mixers, digital audio interfaces, etc. -- that do not use tubes -- have op-amp inputs and op-amp outputs. Op-amps have a high input impedance and a low output impedance. So connecting the op-amp output of one device to the op-amp input of another device works very well. Following Ohm's Law, going from the low output impedance to the high input impedance typical of most line-level devices, the resulting signal loss is negligible. For example, an output impedance of 100 Ohms and an input impedance of 20K results in -.04dB -- a few hundredths of a Decibel. If instead it were a loss of a few tenths or a few thousandths, it wouldn't make any audible difference. (Yes, differences in input impedance can effect the sound of mechanical sources such as guitars and microphones that can "see" a load. These impedances can be frequency dependent within the audible range. This is one reason why mic-pre's and fancy DI boxes often have variable input impedance.) People often ask about "standards" such as "-10dB" or "+4dB". In practice, "+4dB" is pro line level, and "-10dB" is consume/musician line level, although no specific standards exist. Within a studio, having equipment that is "+4dB" is important. It prevents having to attenuate and boost the signal unnecessarily when connecting devices to each other. Which would increase noise and reduce dynamic range. In other words, consistently maintaining a signal level of around 20Vpp provides the best sound quality. So what if you want to use a piece of "-10db" equipment, such as keyboard or effect pedal, with your "+4dB" studio gear?? As long as the output impedance is lower than the input impedance, which is almost always the case, you can connect one to the other. What about the signal level?? When going from "+4db" to "-10db" you might have to attenuate the signal, and when going from "-10db" to "+4db" you might have to boost the signal. Most devices have input or output level controls, or both, so you do not need to use a third piece of equipment. If you are going from a higher level to a lower level it is very good idea to turn down the levels first. If it's too low, turn it up. If it's too high, turn it down. You only need to "match levels" if there are no level controls. For example, I have a Drawmer 1960 for sale on Eb*y that supports both "standards". It has two sets of insert points -- "+4dB" (for pro rack gear) and "-10dB" (for guitar pedals). Why?? Since there is no gain control at the send and return points, it uses its own internal "match box". A handy tool for any studio is a small analog mixer. I love my Mackie 1202. You can buy one for around $175 on the used market. It's a matchbox, a mic pre, a headphone amp, mixer, etc. Not only can it change the level of any audio signal, it can also replace a number of adapter cables. It's very useful for connecting "-20dB" consumer devices such as tape decks and VCR's to your other equipment. Pretty much everything, with the exception of tube gear, that runs off of AC uses -15/+15 volt rails internally. MOTM is no exception. As long as the input voltage does not exceed the rails, damage should not occur. So you should be extra cautious when going from "+4dB" (which is typically around 20Vpp, but can be as high as 28Vpp) to effect pedals that run off of lower voltages such as 9V batteries. The outputs of MOTM modules are much lower -- 10Vpp is somewhere between "+4dB" and "-10db". I have connected MOTM to pedals from Boss, DOD, Electro-Harmonix, Ibanez, Morley, Mutron, Pearl, Sovtek, etc. without any problems. Notice that the output level of most pedals is much higher than the output level of a guitar (several volts vs. a couple tenths of a volt), yet people offten connect pedals to each other. If you attenuate the signal by sending the output of an MOTM module (10Vpp) through some sort of "re-amp" or "connect to anything" device to get an instrument level output of 200mVpp, then send that to an effect pedal and amplify it by turning up its input or "drive" knob to get an optimal signal level (~9Vpp), all you are doing is attenuating the signal by around 30dB then amplifying it by around 30dB. You are not accomplishing anything except increasing the noise and lowering the dynamic range of your signal. That being said, if you are some sort of guitar pedal fanatic you might want to read the next two paragraphs. If I didn't write them, I would probably skip over them myself. Not all stomp boxes have op-amp inputs, or op-amp outputs. This is especially true of "vintage" pedals. Some use emitter followers which provide a high input impedance, but not all of them do. The low input impedance of a few pedals has a desirable effect when used with guitars (eg. the way a Fuzz Face loads the pickups is a large part of its sound). While there is absolutely no standard for effect pedals, and various manufacturers have made some awfully bizarre designs over the years, their input impedance is rarely an issue since guitars have a high output impedance. The issue is that some pedals do not have a low output impedance (for the exact same reason that guitars don't either). It can be 10K or higher. This isn't an issue if they are connected directly to an amp, since guitar amplifiers have an extremely high input impedance (typically 1M). However, largely due to the use of output capacitors that form RC filter networks, it can effect the sound when pedals are connected to other gear, or even to other pedals. This effect on the sound is only an issue when compared to using a guitar and an amp. If you are using pedals with a modular, it is never going to sound like a guitar and an amp no matter what you do. If for some bizarre reason you need to have a vintage pedal exhibit the same exact behavior that it would with amp, then you need an active direct box with an input impedance of 1M. A passive box won't do it -- using a transformer with a 10:1 ratio connected to a 20K line level input would result in input impedance of 200K. That's also a typical input impedance for many active DI boxes and AD converters. For example, the instrument inputs on my Metric Halo 2882+DSP interface are 200k. While that is perfectly fine for most applications, it still doesn't have the 1M input of a guitar amp. However, there are active DI boxes have input impedances of 1M (and a few active DI boxes intended for studio use, where cable noise is less of an issue, have switchable input impedances as high as 10M). So if you are a fanatic, you'll need one of those. What about balanced connections?? MOTM modules do not have balanced inputs or balanced outputs. This is a very good thing. Unless you are in a ridiculously hostile environment, there is no reason to use balanced connections for 10Vpp signals over distances of several feet. If you would like to connect your MOTM modules to a device that only has balanced connections, please see this document: http://www.rane.com/note110.html DISCLAIMER: My first name isn't "Paul" and my last name isn't "Schreiber". I'm not an EE. YMMV. If you blow something up, that's your problem.
2006-10-22 by Richard Brewster
Nice overall explanation, Mark. Regarding the snippet below, I wanted to point out that although MOTM output level are typically 10Vpp, MOTM modules can put out up to 28Vpp or so (limited by the power supply rails). The 510 Wave Warper is one. Some of the filters can put out high levels too, and the 190 VCA's will pass large signals through. Richard Brewster http://www.pugix.com Mark wrote:
> Pretty much everything, with the exception of tube gear, that runs > off of AC uses -15/+15 volt rails internally. MOTM is no exception. > As long as the input voltage does not exceed the rails, damage should > not occur. So you should be extra cautious when going from "+4dB" > (which is typically around 20Vpp, but can be as high as 28Vpp) to > effect pedals that run off of lower voltages such as 9V batteries. > The outputs of MOTM modules are much lower -- 10Vpp is somewhere > between "+4dB" and "-10db". I have connected MOTM to pedals from > Boss, DOD, Electro-Harmonix, Ibanez, Morley, Mutron, Pearl, Sovtek, > etc. without any problems. > > >
