2 more things....
2006-10-10 by Paul Schreiber
a) I turned the kits "off" in the cart until tomorrow, 9PM. I need to start with an accurate inventory count. b) MOTM-910 pc board prototypes ordered today. These use the 'standing up' Switchcraft-style jack, that you will be seeing a lot of. They are made by Switchcraft but are an 'OEM RoHS version' not labeled Switchcraft (like a 'white box' software product). If the prototypes solder up OK, then I will order 50 pc boards and have plenty of 910s available. The board as a ground plane to reduce crosstalk and ground noise. Paul S.
