650 Question
650 Question
2006-10-09 by muffwiggler
Can the 650 be configured to output hz/V, or only v/Oct?
Can it do both at the same time on seperate outputs?
Re: [motm] 650 Question
2006-10-09 by Scott Juskiw
It doesn't do hz/V at the moment, although Paul has said this will be
an added feature someday.
2006-10-10 by J.D. McEachin
The 650 can do whatever note to 10 Volt mapping you want, it's just a matter of sending it the right tuning data via midi.
The 650 was supposed to ship w/ hz/V as one of the default tunings, however, it hasn't happened yet.  I am still waiting for someone to supply me w/ the data so it can be incorporated into the firmware.
At present, no.  If it's possible w/ the resources available, I could see adding it in the future, because I have at least one hz/V monosynth that I'd like to control w/ the 650.
Jeffrey
