circuit needed
circuit needed
1999-12-10 by velure
this may seem trivial, but...
i'm looking for a circuit.  i need to convert a standard trigger pulse to
s-trigger.
what is s-trigger?
i am trying to trigger a mono/poly from a 606 via an MOTM-420.  i want the
filter to hit on the beat of the mono/poly's arp.
-steve
Re: circuit needed
1999-12-10 by Paul Schreiber
S-Trig means Shorting to Ground.
All you need is an inverter. A NPN transistor and 3 resistors will work.
Power it from a 9V battery.
If you need more specific, I can draw it up.
To: <motm@onelist.com>
Sent: Friday, December 10, 1999 4:13 PM
Subject: [motm] circuit needed
> From: "velure" <velure@...>
> s-trigger.
> what is s-trigger?
> -steve
Re: circuit needed
1999-12-10 by Mark Pulver
 >s-trigger.
http://machines.hyperreal.org/manufacturers/Moog/schematics/moog.trigger-con
Mark
__________________________________________________________________
Do you like pictures? http://www.midiwall.com/synths/gearpics.htdl
