interfacing ?'s
interfacing ?'s
2006-09-22 by pow333us
Hi everybody,
how do folks on this group deal with recording their modular? My plan
was this, I as going to come out of the synth into a api type mic pre
with a built in DI. I wanted to go In to the DI and from there through
an OPAMP gainstage, output transformer and into my compy interface (
an MOTU 896 in this case) and it would be great, I'd be recording
squiggles and blips and then sequencing them. I planned to be so
happy. Finally I got all the pieces in place but the synth was too
hot. I was running oscillators into a motm filter and Wow, the output
of the filter was gigantically huge. So I switched to the mic pre
input and padded it down 20 db. Still so huge. Do i really need to get
a DI in between the synth and the pre? I really want some iron between
the synth and the computer. What do y'all do? I'd really like to know
how folks record their modulars so that i can have a variety of
techniques to choose from, unless there is just one way to do it.
Paulo
Re: [motm] interfacing ?'s
2006-09-22 by Stephen Drake
Why a mike pre? Nothing mike like in these boxes.
I run mine straight into a mackie 1202vlz, not the mike inputs, just
the regular line inputs. From there into an m-audio audiophile usb,
then into the mac and cubase. No problems.
On 9/22/06, pow333us <fluxivity@...> wrote:
> Hi everybody,
>  Thanks
>  Paulo
Stephen Drake
sduck409@...
makeme1witheverything@...
2006-09-22 by SC12R21@AOL.COM
Well..........I don't have any MOTM modules but I do have a rather large Synthesizer.com modular that I input directly into the external inputs of a Korg Wavestation in order to use its internal effects. From there the output of the Wavestation goes directly into a Roland VS 2480 Digital Studio Recorder. Works wonderfully. SCR
To: motm@yahoogroups.com
Sent: Fri, 22 Sep 2006 10:04 AM
Subject: Re: [motm] interfacing ?'s
> Hi everybody,
> Thanks
> Paulo
Stephen Drake
sduck409@...
________________________________________________________________________
Check out the new AOL.  Most comprehensive set of free safety and security tools, free access to millions of high-quality videos from across the web, free AOL Mail and more.
2006-09-22 by Matthew Hiscock
I used to use a RME hdsp 9632 card and highly recommend it (just not with a UAD-1 card...) and it had a setting to select the input level between -10dB/+4/"lo gain". I almost always used the "lo gain" setting for my modular, which is a dotcom/motm mix.
Now I use a Focusrite Saffire LE and it's set to "Line" not "Instrument" so the preamps are pretty much bypassed. If you have a similar option, I'd recommend it, though I still do have to take the volume down a touch from full on the VCA, since there's no "lo gain" option.
I have noticed differences between filters, tho. My '420 and '410 are a touch louder than my '490, and so require more attention paid to the input level.
Matthew
On 22-Sep-06, at 12:32 PM, pow333us wrote:
Hi everybody,
Paulo
Yahoo! Groups Links
<*> To visit your group on the web, go to:
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
(Yahoo! ID required)
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
site: http://www.bodega-audio.com
myspace: http://www.myspace.com/bodegaaudio
2006-09-22 by Scott Juskiw
>Hi everybody,
My MOTM synth goes into a mixing board (line inputs). The mixing
board has 8 subgroup sends which I patch to the 8 inputs of a MOTU
1224 A/D converter. This allows me to record 8 channels at once. The
board handles lowering the 10Vpp MOTM levels to something that the
1224 is happy with.
Re: interfacing ?'s
2006-09-22 by crmatt99
I have some apis also, if you realy want to use them for that sound, you will need to pad
the input and also the output, the api's are very hot on most things and you will not get
much evidence of the "iron in the path" utill the pre can be boosted. If padding the output
of your synth does not effect any of the dynamics for you then go ahead.
It would be kind of cool if there was a vco made with the api 2525 opamp, but might just
be another expensive module to make stuff a little noisier.
--- In motm@yahoogroups.com, "pow333us" <fluxivity@...> wrote:
> Hi everybody,
> Thanks
> Paulo
